inlet/exhaust manifold washers
- MARINAMAN480
those guys that have got tc's are your washers for the manifolds flat or have they got cut outs on them ? as my inlet and exhust manifolds sit at different heights
Re: inlet/exhaust manifold washers
Hi Lee,
On my SDL Coupe I used MGB parts, the exhaust and inlet manifolds were different thicknesses, with the inlet being thicker. I marked the size of the washers on the inlet flanges and filed them down to the same thickness as the exhaust flange.
- MARINAMAN480
Thats what i got.
Did you file the washers or manifold ?
What did mg do then ?
Sent from my GT-I9100 using Tapatalk
I filed the flanges on the inlet manifold. I can only think that the casting thicknesses varied over the years, I can't see any reason to have two different thicknesses putting the washers on an angle.
Have you checked any of the MGB forums to see what they say?
- MARINAMAN480
Not checked forums but looked at brown and gammons and moss etc
Washers are flat and both manifolds same thickness. Never had that problem.
