I have got around this by machining my own hubs for the disc kit. It gives you the wider track but without straining the bearings and you can fit a vented disc and sliding caliper!
Wheel sapcers, your views
Well I'm not a fan Paul of spacers above 30mm because of the added strain on the bearings. Plus the ones with stud extenders tend to snap! Upgrade to ford studs may help here.
Whoa ..... You called Your Marina "Snowy" ?
Wierd. I know another Morris, albeit a different model, with the same name !
My Uncle had a friend, who owned a Hugely tweaked Morris 1000.
Seats from a Dakota Aeroplane.
Drilled wheels,
etc etc.
(To say how fast it was in its day, his dad had a 2.5 Riley RM and raced "Snowy" to work (A garage) Everyday. And "Snowy" would win, without fail !)
the Numberplate was SNO .... where the nickname came from, and stuck.
He had it written on her
Drilled wheels,
etc etc.
Wanting the 1973 Morris Marina, 1300 Super, Coupe in Blaze at my local classic garage ... HRL 281L ... I want you ! you are YUMMY !
- JIM73
- Have you seen my spoon?
I had 5mm spacers on my old car years ago which cracked and had the misfortune of snapping most of the studs
I replaced with Ford studs at the time to overcome the problem but within a year the osf bottom trunnion went pop !! unfortunately with the wife driving her !! :roll: And yes they were regularly pumped with grease !! So considering the problems i'd advise against using them !!
- JIM73
Yeah it did scare the shit out of me Trev !! It was when we were living in Fareham , wobbly wheels on the motorway wasnt a lot of fun !! :roll:
Paul i can't remember the exact size apart that they were standard Ford studs (about 8 years ago) ATS had them in stock luckily and they fitted ok with no problems !!
In Australia spacers are illegal unless they were original equipment. I would just get the right wheels!
Graham.
Brisbane, Australia
Brisbane, Australia
I'm thinking early Capri Paul the later ones were metric. Take a wheel nut with you to check.eloues wrote:going to have a look at the ford garage tommrow. If thay have some studs i will have the centers driled and threded on the extentions.
Failing that you could always use 10cwt studs. I think MGB are the same... I have a bag of each set here tho mate if you get stuck.
