Wiper motor
pickup
Wiper motor
Post by pickup » Fri Nov 06, 2015 1:41 pm
Its probably on the site somewhere but I cant find it . I need to replace the two speed wiper motor on the pickup . Can anyone tell me which motor it is and the best source for replacement ? Chris .
Re: Wiper motor
Post by JubileeNut » Fri Nov 06, 2015 3:47 pm
Any Lucas wiper motor of the same size will do if it is a two speed. Just be sure not to throw away your old one as the sweep gear changes for example for a Land Rover it will be different.
Dead easy to swap over to your old gear if needed.
I got a Land Rover one and had to do this. Also there are different lengths of worm gear and again if yours is OK easy the swap over.
So in short most motors are the same :thumbup:
pickup
Re: Wiper motor
Post by pickup » Fri Nov 06, 2015 4:14 pm
Thanks Jubileenut ,
Thought that may be the case but worth a check ! Took it apart and thought it could be revived but it was too tired !!
Chris .
Re: Wiper motor
Post by MarinaCoupe » Mon Nov 09, 2015 12:31 pm
These people are supplying all sorts of parts
http://www.carbuildersolutions.com/uk/search?q=Wiper
Looks like a Lucas wiper.
pickup
Re: Wiper motor
Post by pickup » Mon Nov 09, 2015 5:58 pm
some interesting bits on there Chris. Ive made do with my old seats for now by the way .
Re: Wiper motor
Post by MarinaCoupe » Mon Nov 09, 2015 7:11 pm
No probs, I think someone else is interested.
hamish575
Re: Wiper motor
Post by hamish575 » Mon Nov 09, 2015 11:52 pm
They are the same in minis also so easy to buy brand new from the likes of minisport or minispares
Re: Wiper motor
Post by MarinaCoupe » Tue Nov 10, 2015 8:10 am
Yes that's right, but the swept angle that the wipers go through on the screen varies from car type to car type. On the link at posted above, it shows different wheels and arms that fit inside the housing. I'm sure someone will know which one is right for the Marina.
Re: Wiper motor
Post by david painter » Tue Nov 10, 2015 1:33 pm
The Swept angle of the motor is stamped on the wiper plate if my memory serves me correctly it certainly marked on the gears inside motor
