Morris Ital Gumtree
Posted: Fri Aug 19, 2016 6:47 pm
by marina12
Re: Morris Ital Gumtree
Posted: Fri Aug 19, 2016 10:10 pm
by DrSebWilkes
Is it worth the asking price?
Posted: Fri Aug 19, 2016 10:16 pm
by timspencer
Reason(s) for failure
offside front Seat belt has a cut which has significantly weakened the webbing (5.2.2a)
nearside front inner Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner wing holed (6.1.B.2)
offside front inner Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner wing holed (6.1.B.2)
offside front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings floor pan holed (6.1.B.2)
nearside front inner Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner sill holed (6.1.B.2)
Windscreen wiper does not clear the windscreen effectively both fronts (8.2.2)
nearside front Headlamp not working on main beam (1.7.5a)
offside front Headlamp not working on main beam (1.7.5a)
Rear fog lamp not working (1.3.2b)
Rear position lamp(s) adversely affected by the operation of another lamp rears (1.1.A.3f)
passenger door does not latch securely closed bonnet (6.2.B.1a)
Probably not then!
Posted: Sat Aug 20, 2016 9:26 am
Not a very honest description in the advert then. Only 150 miles since last MOT Forgot to mention took it for another one and it failed very badly on body rot. Seen many similar adverts both on Gumtree and Ebay complaining about time wasters think he is a vendor that falls into that category
