Post by balmy » Sat Jul 19, 2014 10:38 pm
1972TCCOUPE wrote:MOT?
And a optimism shower! ;)
Well done Matt.
Post by fruity » Sat Jul 19, 2014 11:29 pm
Road test !!??? :)
Sent from the fruityusbattyus device
Post by Gee tc » Sat Jul 19, 2014 11:30 pm
Lovely job!
Post by Uncle Frank » Sun Jul 20, 2014 8:45 am
Looking good Matt!, glad to see the engine is being put to good use :thumbup:
Post by MarinaCoupe » Sun Jul 20, 2014 8:55 am
Good going Matt, so much space to work in.
Post by PHUQ » Sun Jul 20, 2014 10:06 am
Naa Glen, gotta leave something for next weekend... but hopefully won't be too long.
Actually, we're off to look at kitchens and bathrooms this morning :eek: but this afternoon's plan includes putting that engine crane to good use.
There's not as much room as it looks- it's a standard suburban garage, not too bad on width (about 3' wider than a car as I recall) but it's only about 18" longer than a Marina. It's just unusually tidy 'cos I've turfed all the junk into the barn where my friend keeps his classic lorries...
Ben did all the hard work and Frank supplied the engine (although there's not an awful lot of it left- as it didn't need a rebore there's a lot of Maestro bits in there :) -but without it being a good base we wouldn't have been so lucky!), I've just had the easy bits. Hoping it should look for all the world like a standard Ital A+ less the ribs in the block once it's in. Need a few odd bits to complete the look- Ital solid heater pipe (I have a Marina one thanks to Ben which will work, but the Ital one is a slightly different shape to clear the larger manifold) & the solid section of servo hose for two.
Decided to fit a club (Chris) clutch slave since they are nice and easy to fit with the engine like this & I didn't want to faff around with it again. On that note, I've an exchange for you now Chris, will pop it in the post in the week.
Post by MarinaCoupe » Sun Jul 20, 2014 10:46 am
Great thanks Matt
Martec
Post by Martec » Sun Jul 20, 2014 11:39 am
This is a post to 'Marinadriver',
The head to stromberg carbs, I'm assuming you are going with the steel manifolds, using 6mm strip and thin sheet steel and cardboard for patterns I've made up to manifolds for my engine, one was to fit twin HS6's to an 8 port head and the other was to fit 4 throttlebodies to the 8 port head, so a bit of a welding fest but you get the shape that you want.
For rear suspension have you considered fitting an MX5 rear subframe and all the bits, it is the right axle width and is almost a bolt in fit. I don't know what is available in the US. Also I guy on hear fitted a Lada back axle and rallied it. I have looked at the MX5 route but they are still expensive in our scrapyards at present (a nice project for suspension).
Post by ClaytonSpeed » Sun Jul 20, 2014 7:18 pm
Fitted quarter bumpers to the v8..
Retroreject
Post by Retroreject » Sun Jul 20, 2014 8:08 pm
I made a commercial :) http://www.youtube.com/watch?v=RycEfEH7 ... e=youtu.be #Marinanotforsale :)
1974 1.3 SDL Coupe. My god..is it supposed to drive like this? :D
Post by PHUQ » Sun Jul 20, 2014 8:11 pm
:mr green:
No, it dunt work yet, be patient :lol:
Post by MarinaCoupe » Sun Jul 20, 2014 8:14 pm
'Kin brilliant movie!
Kiwi Ute
Post by Kiwi Ute » Sat Jul 26, 2014 10:19 am
What did I do today?
Fixed the broken inner cable on the choke.
And replaced the bed-spring sized return spring for the choke with something more sensible!
Post by MarinaCoupe » Sun Jul 27, 2014 8:41 am
I went to the Silverstone Classic yesterday, no Marinas though. Random shots taken on my iPhone.
Post by JubileeNut » Sun Jul 27, 2014 8:57 am
Nice. Was the BMW screen trim similar to the Marina?
