Post by marina12 » Tue Aug 26, 2014 6:41 pm
1.3 Coupe good find. Better than me at finding.
Post by locost_bryan » Tue Aug 26, 2014 9:56 pm
beniboyz wrote:Image
Were those door mirrors factory fitted? I've only ever seen mirrors bolted to the door skin (like the neighbouring Mumford) - these look like they're attached to the quarterlight window? :-?
Post by JoshWard » Tue Aug 26, 2014 10:27 pm
Standard MK3 door mirrors. MK3s had no quarterlight window.
Post by locost_bryan » Tue Aug 26, 2014 10:37 pm
JoshWard wrote:Standard MK3 door mirrors. MK3s had no quarterlight window.
Ah, something that is different on NZ Mk3s. All Kilroy's have fixed quarterlights and bolt-on mirrors.
Post by JoshWard » Wed Aug 27, 2014 12:21 am
Never noticed that before! Guess they had a stock of parts they wanted to use up!
Post by Kilroy » Thu Aug 28, 2014 6:42 am
Thats a negative.
They all have opening quarterlights.
The mirrors bolt to the top of the door - as opposed to the late 575 I have where the mirrors bolt to the fillet in the front of the window opening - and which has no quarterlights at all.
Post by locost_bryan » Thu Aug 28, 2014 11:09 pm
Kilroy wrote:Thats a negative.
Jeez, I'd never make a policeman, hadn't noticed that. :oops:
Hopefully the opening quarterlights are the same as the Mk1 - would you happen to have any good rubbers for the passengers side quarterlight? (if I can't find one in Ben's stash when I meet him at his lockup in a few weeks)
Can anyone tell me if the rear armrests are the same on a coupe as a saloon? Or the fronts, for that matter?
Post by MarinaCoupe » Fri Aug 29, 2014 7:03 am
Bryan in the UK the Mk1 quarterlights had a flat profile on the bottom edge, as you can see in Kilroy's picture the later cars quarterlight glass has a different profile, with a slight lift at the front. The rubbers are different, but I guess might be modifiable with a bit of effort.
Post by locost_bryan » Tue Sep 02, 2014 12:10 am
MarinaCoupe wrote:Bryan in the UK the Mk1 quarterlights had a flat profile on the bottom edge, as you can see in Kilroy's picture the later cars quarterlight glass has a different profile, with a slight lift at the front. The rubbers are different, but I guess might be modifiable with a bit of effort.
Did the UK have any models with opening quarterlights, or were these only an "export" option?
Post by MarinaCoupe » Tue Sep 02, 2014 7:00 am
UK Mk1 TCs, and then MK2 GT/HLS and Specials, LEs etc. There were also pop open rear passenger windows on the Coupes.
Post by ClaytonSpeed » Tue Sep 02, 2014 8:32 am
MarinaCoupe wrote:UK Mk1 TCs, and then MK2 GT/HLS and Specials, LEs etc. There were also pop open rear passenger windows on the Coupes.
That's a negative good buddy. UK MK1's don't have front or rear opening quarters. They were an export option.
Post by MarinaCoupe » Tue Sep 02, 2014 8:34 am
What about Paul's Jub?
Post by ClaytonSpeed » Tue Sep 02, 2014 9:15 am
Special edition though. Main stream cars didn't have them
Post by Gee tc » Tue Sep 02, 2014 9:35 am
Our LE had them. Both my T C s not.
Post by JubileeNut » Tue Sep 02, 2014 7:58 pm
Mines got a pop open roof as well :shifty:
