Getting the gearbox back in is always the hard bit.
Trouble with going too high on axle stands is you loose stability. I dont like being underneath a car at the best of times.
Gearbox removal.
- MARINAMAN480
Re: Gearbox removal.
well done in doing your gearbox,
have done this a few times on my back , i drive the front up on to ramps and jack the back up on to axle stands . getting the box off is easy but as you found out putting it back is a prob, i now have an old lay shaft from knackerd gearbox to line up the clutch plate up best thing to have as gearbox goes on first time every time with this.
I am hoping when I do mine I will not have alignment issues as I am not changing the clutch! So gearbox should pop back on.
