yes, but may need spacers as the offset is ET25 compared to Marina's ET13mileschaff wrote:so tr7 will fit ?
will mx5 wheels fit a marina
Re: will mx5 wheels fit a marina
I have TR7 wheels on my brown coupe they clear the uprights without spacers but only just
What offset and size are your wheels david I am kind of thinking of going down the 15" path but unsure what width and offset I can get away with?
Offset is only part of the story, to fit the Marina front suspension, you need to look at the backspace on the wheel i.e. The distance from the inside of the wheel rim to the inside mounting face of the wheel. You should look to keep this under 100mm, otherwise you'll need to use wheel spacers to push the wheel out. If the backspace is more than 100mm the wheel/tyre will rub on the suspension upright and top joint on lock.
Is 100'm the maximum amount? So 15x7 with 0 offset would work but say 8 with a 0 offset would be the limit
Yes - otherwise you'll need wheel spacers.
Anyone knows where would be possible to make spacers to Marina? 95.25/100 and 95.25/108
1976 Marina 1,3 Coupé Deluxe (flamenco)
1977 Marina 1,8 Special Automatic (flamenco)
1976 Marina 1,3 Coupé Deluxe (tahiti blue)
1974 Marina 1,8 SDL Automatic (teal blue)
1974 Marina 1,3 Coupé Deluxe (citron)
1978 Marina 1,3 Coupé Super (jade green met.)
1977 Marina 1,3 Coupé Deluxe (flamenco)
The MGF is also 3.75" and you can buy conversion spacers to match the Ford fitment, try EBay or a Google
http://www.mikesatur.com
