Post by ado28 » Tue Apr 30, 2013 8:45 am
That would be good Chris :)
lock1506
Post by lock1506 » Tue Apr 30, 2013 5:10 pm
Not sure if I'm bringing the van again or the estate this year, plenty autojumble to bring down just depends on how many passengers I have.
Post by ado28 » Tue Apr 30, 2013 6:32 pm
Bought some more flap disks and other bits n bobs then continued with the rear quarter panel :-D
Post by ScreamingLordStokes » Thu May 02, 2013 8:10 pm
Fitted reconditioned propshaft and new centre bearing - wow! Judder-free getaways. :D
Post by ado28 » Thu May 02, 2013 9:25 pm
No work done on the pick up today as Reynards exhaust snapped in half lol. I have finally bit the bullet and ordered a stainless system for him however that will take a few weeks to arrive so in the meantime I have decided to repair Reynards exhaust. Fortunately I have some scrap sections of exhaust lying around so I can at leat get it all back together again. The middle box has been patched with fresh metal so hopefully that will be leak free when I put it back on. The rear box was kaput so thats binned and a good second hand spare is ready to replace it. Tomorrow I will hopefully have Reynard back up and running. One thing I could really do with is the clamp where it attaches to the gearbox and exhaust. Does anyone know where I can source this bit from? Failing that I'm sure I will conjure up something up :)
Post by JubileeNut » Thu May 02, 2013 10:42 pm
Where did you get your reconditioned prop from?
I have a similar problem and it may also be causing a bit of judder
Cheers,
1972TCCOUPE
Post by 1972TCCOUPE » Fri May 03, 2013 3:19 pm
Paul, I got mine from the bay. It's a dolomite one see,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0940760442 if that link works
Post by MarinaCoupe » Fri May 03, 2013 3:28 pm
Yup shared with Marina.
Part no. 37H8019 is a Marina part no.
Sent from my iPhone
Post by ClaytonSpeed » Fri May 03, 2013 3:30 pm
I think Paul was after a recon prop, not the centre bearing .. But I may have read that wrong?
Post by MarinaCoupe » Fri May 03, 2013 5:00 pm
I have used Reco-Prop in Luton - v. Good. I expect that there is someone more local to you though.
http://www.reco-prop.co.uk/
Sent from my iPhone
Post by JubileeNut » Fri May 03, 2013 7:41 pm
Newnham Engineering
I should go and see this place just round the corner from me. See what they could do :think:
I found out it is owned by my late fathers cousin!
Bobs your Auntie :thumbup:
I did mean the whole prop. my centre bearing is new ish but slope in sliding joint and may be diff so causes a bit of jitter on pull away sometimes.
Thanks for the replies :thumbup:
Post by ScreamingLordStokes » Fri May 03, 2013 8:22 pm
Cheers,
Hello Paul, I took my old propshaft to a place in Sheffield called (wait for it...) "Propshaft Greno" located in a district called Grenoside. They are a very old establishment who also do most automotive engineering work such as recutting valve seats, re-bores etc. I took it in Friday after work and it was all ready for Tuesday. It made a massive difference to my car as one of the UJs was totally shot with rusty needle rollers, not only was it causing juddering, i could feel the car wobbling as if it was running on three cylinders!
Post by JubileeNut » Fri May 03, 2013 8:33 pm
Glad it has made a great difference. It may be what I have had as I know the sliding joint is loose but all UJs and centre fine :thumbup:
Post by ado28 » Fri May 03, 2013 8:34 pm
My A60 used to judder quite badly until I replaced the UJ's
Post by MarinaCoupe » Fri May 03, 2013 8:48 pm
Assuming you've got a circlip type propshaft (not stake/crimped) then with some suitable sized sockets and a vice or at a pinch a good G clamp, you should be able to change the needle bearings yourself. The biggest problem usually is getting broken circlips out - it is doable.
