Im glad you had a good but damp weekend Sean tels hope its sunny next year.
Peterborough - BMC / BL Rally & Spares Day
- northeastmarina
Re: Peterborough - BMC / BL Rally & Spares Day
As if you needed to fit a shower in your marina
by the time i got home there was more water in the boot thanks to my leaky rear lamps than in my raiator.
BRITISH IS BEST
No leaks in Reynard, he remained nice and dry during the torrential rain
ha ha, good one Chris!MarinaCoupe wrote:No leaks here either, but there a lot of sub-marinas.
http://www.marinacoupe.co.uk
- vermillion
Show offado28 wrote:No leaks in Reynard, he remained nice and dry during the torrential rain
Gary.
Good news is mine will be dry for the IOW, It may mean no rain - Lets hope so
He used to leak like a sieve Gary. I thought it was leaking through the screen so I plastered it with sealant but it still flooded like hell even in short showers. I dug deeper while recommissioning Reynard and found that my N/S A post was holed and soft in places so I cut out the rot and welded fresh metal in and now he's water tight!
- vermillion
That might be a good explanation for why my SDL leaks like a sieve, not so sure about the Mumford thoughado28 wrote:He used to leak like a sieve Gary. I thought it was leaking through the screen so I plastered it with sealant but it still flooded like hell even in short showers. I dug deeper while recommissioning Reynard and found that my N/S A post was holed and soft in places so I cut out the rot and welded fresh metal in and now he's water tight!
Gary.
Check between the top and bottom hinge Gary. Mines looked ok until I started poking it with a screwdriver. At one point I had the garden hose on the car to try and find the leak as it was just weeping out from the top of the sill/ bottom of the a post
Sent from my GT-I9300 using Tapatalk 2
Also a very good explanation as to why JWC leaked so much
- vermillion
Thanks for that Frank, you could have told me sooner
Gary.
Gary.
My saloon also leaks through the n/s A post, although its not corrosion but two small holes left unfilled where the welds of an old wing were chiselled off or drilled out. I only realised this due to the recent torrential rain.
Might have something to do with the roof lolUncle Frank wrote:Gary....it`s a Mumford convertible, they all leak!
