Page 1 of 2
Braided Brake Hose
Posted: Sun Feb 02, 2020 8:43 pm
Does anyone know of a manufacture of Stainless steel Braided brake hose set for the Later Morris Ital with telescopic front dampers the type that screw directly into the caliper rather than the ones with the little metal pipe to caliper
Thanks in advance
Re: Braided Brake Hose
Posted: Mon Feb 03, 2020 7:50 am
David,
These people made my set for me. They have a big book, with all the hose descriptions, dimensions, threads etc.
http://www.stevsonmotors.co.uk/Stevson% ... epage.html Based in West Midlands somewhere.
Posted: Mon Feb 03, 2020 7:51 pm
Thank you for the reply Chis I have looked at the website link and will ring them this week
Posted: Mon Feb 03, 2020 9:36 pm
by MARINAMADBAZ
I've got some on the Ital will get number off them baz
Posted: Mon Feb 03, 2020 10:29 pm
That great Baz Thank you
Posted: Wed Feb 05, 2020 10:50 pm
by MARINAMADBAZ
gbh219 I think check my handwritten part no.book put this as ital
will check on the car it's at my dad's
baz
Posted: Thu Feb 06, 2020 7:49 pm
When I Googled the GBH219 that Baz suggested it came back as a rear hose on a TR7. A local Brake supplier to me has come up with a new TRW hose not sure of number at present but is listed as fitting a Bedford CF250 it does however look right I will have a play at the weekend. If its ok I have something to work with.
Posted: Fri Feb 07, 2020 8:33 am
Hi David
I have a lovely paper Moprod hydraulics catalogue, that gives details by model, part number, all vehicles using the same part so here we go.
Ital options
It’s the late Ital pipes we are interested in so the front hoses are BH119 & the rear BH201
Rear pipe
Front pipe
Posted: Fri Feb 07, 2020 1:02 pm
by MARINAMADBAZ
my mistake gbh216
these are longer and screw straight into caliper.
the good ridge no.gbh216gr
baz
Posted: Fri Feb 07, 2020 1:18 pm
Thank you both for the replies the one I have here is a TRW PCH228
Posted: Fri Feb 07, 2020 6:06 pm
The tables give you some cross-references into cars where stainless braided hoses are readily available.
Posted: Sat Feb 08, 2020 4:49 pm
Thank you both. With the pictures Chis put up and some online catalogues and my original marina BL catalogue I have discovered that the front hose is a
GBH 211 same as front on Stag and 2000/2500 range I have compared the new TRW hose I have with my pick up and my Stag it is the same the MGB listing is 22 mm shorter. The rear is GBH138 the same as Dolomite and Spitfire/GT6 range rear hose. Tomorrow I am going to the Triumph / MG spares day at Stoneleigh so will see what I can find
Posted: Sat Feb 08, 2020 5:15 pm
Good stuff Dave. I was hoping that you would have enough information to noodle it out. I’m going to Stoneleigh tomorrow as well, maybe see you there? Mobile number 07967 480534.
Posted: Sat Feb 08, 2020 6:06 pm
May well see you down there im going with my mate in his 2500S doing a small Convoy from Telford with two Dolomites. My mobile is 07974 266534
Posted: Sat Feb 08, 2020 7:55 pm
by MARINAMADBAZ
