Spigot bush supplier
Posted: Tue Nov 01, 2011 6:19 pm
by gjmc525d
I have bought a spigot bush for my Jubilee engine but now need to source the outer sleeve ,does anyone know where I can buy one new .
Tried a couple of suppliers but no luck.Does an Mgb engine have the same spigot bush set up?
Any info would be gratefully appreciated :D
Posted: Tue Nov 01, 2011 6:47 pm
Marina B series 1.8, standard gearbox spigot 1/2" diameter. Standard Marina crankshaft 3/4" diameter, so bush should be - 1/2" ID & 3/4" OD.
Earlier Mgbs had a bigger hole in rear of crank, but never fitted by BL to Marina.
www.marinacoupe.co.uk
Re: Spigot bush supplier
Posted: Thu Nov 10, 2011 8:16 pm
by Coupedriver
Chris: Did the info in my PM help? Skip
Posted: Thu Nov 10, 2011 9:04 pm
Skip
Not seen a PM sorry
Posted: Thu Nov 10, 2011 10:19 pm
by jiversteve
Does this help?
http://www.pte-ltd.co.uk/pdf/oilite2.pdf quite a choice of sizes.
Posted: Thu Nov 10, 2011 10:27 pm
by Coupedriver
Oops, it was for gjmc525d--I thought he was Chris. Sorry--I need a keeper... :D Skip
Posted: Fri Nov 11, 2011 2:11 pm
by gjmc525d
Thanks for all the info,hopefully will get something sorted :D
Posted: Mon Jun 11, 2012 11:21 am
Did you get this sorted out? I need the big bush for my T16 conversion. If yes where did you source it?
Posted: Mon Jun 11, 2012 9:35 pm
I had the same requirement when using a crank from an auto for a manual.
As no bush had ever been fitted, there was a large hole in the crank. I asked the engine reconditioners if they could make one, but they said it would be too difficult/expensive/something to do so from bronze.
Instead, they made a steel spacer, and the original bronze bush fits in that.
I did supply a crank with a bush already in it - but they could not get it out without destroying it.
Hope that is of interest.
Posted: Mon Jun 11, 2012 9:49 pm
LeacyMG in the Uk has them on back order. They are having 300 made, but they will be about 2 months, so I have resigned myself to getting a local engineering co. to make me one. I had come to the same conclusion as you and was planning a steel bush to take a needle roller spigot bearing.
Mine will have to be a Frod bearing to match the gearbox though.
Posted: Mon May 16, 2022 6:49 pm
by martinclan
Old thread this I know. But did anyone locate a source for the spigot bearing. I looked at the above mentioned Leacy Web site and they don't list them, or anything else for the Marina!
Cheers Robin
Posted: Mon May 16, 2022 9:09 pm
Posted: Tue May 17, 2022 10:04 am
by martinclan
Thanks Chris
So I assume this is an alternative as it seems to be a Land Rover part. I can see it is a needle roller bearing which is going to be superior to the original which I believe was a oilite style bush?
Cheers, Robin
Posted: Tue May 20, 2025 9:13 am
by martinclan
Just returning to this subject. I bought a needle roller bush from a well know classic car pars supplier. It has the correct part number but, slightly worrying, says made in Taiwan on the label...
To cut a long story short I thought I would test it for a fit on the gearbox input shaft before I pressed it into the crankshaft. It is a very, very loose fit. Is that normal? Perhaps it will be better once it is pressed into the crankshaft which must compress it slightly?
Cheers, Robin
