Mk3 Gold saloon
Re: Mk3 Gold saloon
Great progress Lee, looks really smart.
I assume the plan is new shells (since you're in that far) but to standard size?
- MARINAMAN480
Re: Mk3 Gold saloon
Thanks im leaving the shells alone as they well within tolerance plus standard size ones proving hard to find.
Sent from my SM-G981B using Tapatalk
Re: Mk3 Gold saloon
Fair enough. I'd normally say replace them as a matter of course but if you can't find good quality new standard size ones that rather forces your hand!
Re: Mk3 Gold saloon
Could be a set of standard mains listed here http://www.bowdenengineparts.co.nz/pdf/bearings.pdf
Re: Mk3 Gold saloon
Great work there, and well done with the 2 litre, they go really well.
For future reference I have quite an assortment of new bearing sets and I am pretty sure there are standard sets there.
Best luck.
Best luck.
- MARINAMAN480
Re: Mk3 Gold saloon
Thanks Kilroy im still keeping a look out for bearings, whilst the engine is still this far stripped , still no luck for standard size,plenty of oversized ones out there tho .Kilroy wrote:Great work there, and well done with the 2 litre, they go really well.
Best luck.
Re: Mk3 Gold saloon
https://www.fwthornton.co.uk/search?fil ... ambassador
Might help. These people were very helpful when I needed parts last year.
- MARINAMAN480
Re: Mk3 Gold saloon
Thanks , forgot about the Ambassador.ClaytonSpeed wrote:https://www.fwthornton.co.uk/search?fil ... ambassador
Another lead i got was some of the Rover 820's had the O series in.
Re: Mk3 Gold saloon
All the O, M and T series bearings will inter fit with each other.
- tathoarder
Re: Mk3 Gold saloon
Nice work Lee, what did you use to paint the engine bay?
- MARINAMAN480
Re: Mk3 Gold saloon
Thanks Ben contacted this company and had everything i neededMARINAMAN480 wrote:Thanks , forgot about the Ambassador.ClaytonSpeed wrote:https://www.fwthornton.co.uk/search?fil ... ambassador
- MARINAMAN480
Re: Mk3 Gold saloon
Thanks just used Rattle cans mixed to match the paint code then clear coat lacquer over thattathoarder wrote:Nice work Lee, what did you use to paint the engine bay?
Re: Mk3 Gold saloon
Ah excellent!MARINAMAN480 wrote: Mon Jun 28, 2021 5:14 pmThanks Ben contacted this company and had everything i neededMARINAMAN480 wrote:Thanks , forgot about the Ambassador.ClaytonSpeed wrote:https://www.fwthornton.co.uk/search?fil ... ambassador
If I can be of further assistance on the build let me know.
Re: Mk3 Gold saloon
FWT is owned by a mate of mine's family always very helpful and have enormous stock. They have been buying up closed down Garage/Dealer stock going back to the 20's/30's. Until they moved to the NBC site in Telford, a few years ago the shop at the bottom of the Cop in Shrewsbury had hardly changed since then. A real Aladin's cave. They did feature once with old Fuzz on Car SOS.
- MARINAMAN480
Re: Mk3 Gold saloon
Certainly a good company all the bits i ordered arrived today
