Rear shock absorbers
Woody
Post by Woody » Tue Apr 15, 2025 10:22 am
Hi folks, I bought a pair of shockers from eBay in Nov, the seller checked my reg and assured me they were the correct ones. (Can you see where this is going?!) roll on April and the nicer weather, and it was time to do the job. Turns out my original eyebolt top bush is ½” and the new one is 3/8”. I’ve tried contacting the eBay selling for a replacement /refund, but funnily enough he has cocked a deaf ‘un! Does anyone know please, of anyone who still sells rear shocks? I’ve tried the chap at Longbridge Motor Spares, but if he doesn’t return your call, that usually means he hasn’t got the part!
Cheers all.
Rob
martinclan
Re: Rear shock absorbers
Post by martinclan » Tue Apr 15, 2025 4:41 pm
I have Spax adjustables. Not cheap - but they do fit :-)
Post by locost_bryan » Wed Apr 16, 2025 2:37 am
Post by locost_bryan » Wed Apr 16, 2025 2:41 am
Post by MarinaCoupe » Wed Apr 16, 2025 7:55 am
The crush tube in the middle of your shockers are quite thick, if you are careful you should be able to drill or ream out the holes to 1/2”.
Alternatively, if you can push out the existing crush tubes with some sockets in a vice, you could then push in some correct dimension tubes, either from your old shocks, or some stainless steel tubes. I think that these are the right dimensions, but if not SuperFlex have lots of alternatives. https://www.superflex.co.uk/proddetail. ... F460-2335T
Woody
Post by Woody » Thu Apr 17, 2025 12:41 pm
Thanks for the advice folks
Woody
Post by Woody » Thu Apr 17, 2025 12:42 pm
locost_bryan wrote: Wed Apr 16, 2025 2:41 am Monroe shocks on Ebay
https://www.ebay.co.uk/itm/267002779113
These are the ones that have caused my issue! :rolls: But thank you anyway
