FOA site admin
rubythursday
Similar problem also although the post does get submitted.
Ruby Thursday
http://www.roverp2.org.uk
1939 Rover 10, 1946 Rover 16, 1957 Series 1 Landy, 1971 Rover 2000 auto, 1974 Morris Marina SunTor, 1974 Marina 1.8 estate auto, 1977 Range Rover Auto, 1988 Range Rover Vogue SE auto, 2004 Land Rover TD4 auto, 1981 Sprite Compact caravan.
- The original northen boy
Me as well fellas.
Russ
Beckett Bros " i alway feel that somebodies watching me" :roll:
Russ
Last edited by The original northen boy on Sun Aug 17, 2008 5:58 pm, edited 2 times in total.
- martinmarina
ayrshirelad32
- stuthegasman
ayrshirelad32
sometimes i can post and everyting goes a ok but other times it comes up the debugging sign.Seems either to be a intermitent fault or just gremlins at times.
long live bl s tin
1978 Morris Marina 1.3 super
1979 Morris Marina 1.3l
1979 Morris Marina 1.7l
1980 Morris Ital 1.3hl
1981 Morris Ital 1.7hls
1983 Morris Ital 1,7slx
ayrshirelad32
How come the posting times are an hour behind the actual poating times if they are in GMT? I noticed this the other nite but thought it was just my comp/I s this the same with anyone else or is it the server going with different times?
long live bl s tin
Ok first off I have let Ben know about the debug thing and he needs to sort it but as he is moving house he is without internet for a while - I know it's annoying but please bear with it for a while!
Secondly if you access your profile you can change the clock there, mine is correct so probably just a problem there
rubythursday
It happens to me and I'm not using Microsoft stuff at all.
Ruby Thursday
- Clan Chieftain
- The General
rubythursday
Just done a bit of research into this problem and it is probably down to the hosting company tweaking settings on the server or upgrading the software.
It seems to be happening to quite a few forums. Fixed my forum by changing the admin to use SMTP rather than using the internal default settings.
Ruby Thursday
