* DO AFTER MARKET WHEELS SPOIL THE ORIGINALITY OF THE CAR? *
The original northen boy
Re: * DO AFTER MARKET WHEELS SPOIL THE ORIGINALITY OF THE CAR? *
Post by The original northen boy » Fri May 08, 2009 1:43 am
Ay Up Trev,
So not really a problem then,i'm sure any downside aspects are more than compensated for on the fuel saving aspects,i wonder what a correctly fitted 5 speed gearbox would make to the the arrangement?
So off the top of your head how much extra per tank/gallon of the old go-go juice are you getting now you have under taken the wheel and diff swap?
Russ
Beckett Bros "sneaking out the back door" :roll:
Post by MarinaCoupe » Fri May 08, 2009 7:49 am
To pick up on Russ's question on the 5 speed box. The fifth gear ratio in the Sierra box is 0.82 or to put another way 18% overdriven.
Clearly unless you were to drive around in fifth all the time you won't make an 18% saving, I'm hoping for 7-10%.
By the way, the previous gearbox that was fitted included the J type overdrive which was 25% overdriven so potentially even greater economy.
billytits
Post by billytits » Fri May 08, 2009 8:37 pm
hi russ
without going into all the maths which i'm poo at, around about 35 to 40 miles a tank if driven at the speed limits. most of my trip to work is motorway or fast A roads the one thing i do know is i dont have to visit my garage to fill up as often, and when the 1700 lump go's in it would be rude not to put a type 9 in there so i will be needing one of the lovely kits all i need to do is get my hands on the right box, or could i fit the extended v6 shaft into a standard box?
trev
www.morrismarina.org.uk
Post by MarinaCoupe » Sat May 09, 2009 9:08 am
Hi Trev,
Yes we spoke to a gearbox specialist who says that a V6 input shaft will go into a standard 4 cylinder gearbox, something about using the input shaft from a 2.3 V6 Cortina? Assuming that you would have whatever gearbox rebuilt anyway before fitting, that would be the best time to do it, best to speak to whoever rebuilds your gearbox at the time.
There is an XR4i gearbox on Ebay at the moment for little money with a day to go, this has all the right parts already. It's in Crawley which I think is fairly close to you.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0415082289
billytits
Post by billytits » Sat May 09, 2009 10:27 pm
cheers for that chris not quite ready to think about the five speed yet it dosnt realy matter if it needs a rebuild, as that sort of thing is my job, i rebuild big paper machine components from pumps and gearboxes. i will wait for the right one as i know someone who is breaking a siera soon so i can have that box for nothing then fit the exended shaft which im sure i will be able to find. im affraid it boils down to lots to do and no time to do it :roll:
trev
