Data sheet
mk2 golfer
Data sheet
Can anyone from admin please send me a data sheet as I didn't get one in the winter edition of Understeer, I want to send my details down to D. White in Essex but I havent got a data sheet, thanks.
Paul
- marina1300coupe
Re: Data sheet
Hi Paul
You are not alone, also not received, although not as anxious as you to complete a written form.
Ian
Ian
- black tulip tc
Re: Data sheet
What data sheet????????
Re: Data sheet
Yeah! What data sheet?
Not sure what you mean.
- jiversteve
Re: Data sheet
Do you mean this http://homepage.ntlworld.com/c.weedon/m ... on2010.pdf
See Marlin History.
See Marlin History.
- marina1300coupe
Re: Data sheet
black tulip tc wrote:What data sheet????????
Clearly some clarification needed here so take a look at 'Understeer WINTER 2009' page 19 bottom half 'MMOC National Survey and Register' and all will be explained!.JubileeNut wrote:Yeah! What data sheet?
Obviously do not know without seeing the data sheet.jiversteve wrote:Do you mean this http://homepage.ntlworld.com/c.weedon/m ... on2010.pdf
Ian
mk2 golfer
Re: Data sheet
Hi guys, yeah its deffinately called a data sheet that was supposed to come with the winter issue of Understeer but never did.
Thanks Steve, I did have that one but that went when I filled in my address details for the club membership, this particular data sheet is for:-
Mr D White, Stoney Acres, Tenpenny Hill, Thorrington, Colchester, Essex, CO78JB.
This chap is doing a survey for surviving Marinas and Itals and wants to know the details of them all in an aim to share data within other clubs and get some true facts, so far he has had help from Chris Weedon and the Ecosse club so it can't hurt really can it, I think the info that he wants is something similar to the membership application form details, apart form really personal stuff, like he says the most important info will be:- correct colours, chassis numbers and engine numbers, the current data clearly has mistakes and needs updating and it was decided at the AGM last year that it neede doing and that this chap would do it.
Paul
Re: Data sheet
I sent Darren White all my Jubilee Data to up date the club records as they only had 3 on the records and 1 repeat. I gave them around 25!
But this is normally with your member ship renewal when you send the slip back and I fill it out every year!
Re: Data sheet
Ah ha!
The data sheet should have gone out with the Winter Understeer, but the printer forgot to put them in the envelope. The reason for the attempt to build a complete register is that with the turnover of cars being what it has been, we don't know what has survived and what has been scrapped.
You can send your details to Darren at register@morrismarina.org.uk
mk2 golfer
Re: Data sheet
Thanks Chris I'll do it that way.
Paul
