Post by ado28 » Fri Jul 20, 2012 1:35 pm
This morning I went to my local spray stores and bought some paint and lacquer for Reynard and even picked up a mini spray gun too. I also bought a pair of 6x9's speakers for the parcel shelve. Hopefully the weather will be kind to me this weekend so I can touch the paint work up and start the fit out for the ICE :)
ayrshirelad32
Post by ayrshirelad32 » Fri Jul 20, 2012 2:44 pm
Bumble tucked up in her shed in between Bolly and Eeyore. Roland was getting work done to his front wing. I rubbed down some rust and made the mistake of pokong!. Why did i bother. However 3 days later said bottom of wing ready to be rubbed down again and painted. Took day off form working on car. Heater motor for said car arriving today yipee!. Paddington the Ital awaiting her bootlid refitted. Will paint that over the weekend hopefully. Using the everyday Omega at the mo. Saving Bumbles petrol for next weeks Dumfries show.
long live bl s tin
1978 Morris Marina 1.3 super
1979 Morris Marina 1.3l
1979 Morris Marina 1.7l
1980 Morris Ital 1.3hl
1981 Morris Ital 1.7hls
1983 Morris Ital 1,7slx
northeastmarina
Post by northeastmarina » Fri Jul 20, 2012 2:47 pm
Fitting new qh waterpump after work,then strip+clean the carbs, ;)
BRITISH IS BESTImage
Post by JoshWard » Fri Jul 20, 2012 6:51 pm
Nothing- rain again :rolls:
On the plus side my wheel cylinders are here along with new thermostat and oil filler cap- and sun is forecast for the weekend 8-)
Martec
Post by Martec » Fri Jul 20, 2012 7:41 pm
Fitted the diff pinion seal that arrived today and back on the road.
Shopping trolley(Mazda3)
Post by MARINAMADBAZ » Fri Jul 20, 2012 8:28 pm
New Brake discs and pads fitted on my everday marina
The ones on the car had a 1 inch lip of rust on them and the pads were uneven
Rain didn't stop me i worked under a large fishing umbrella :idea:
Best regards
Barry
Post by ado28 » Sat Jul 21, 2012 9:52 pm
Today I gave Reynard some ICE :)
Post by balmy » Sat Jul 21, 2012 9:58 pm
Rebuilt starter fitted and gained a new MOT.
Barmy
Post by Barmy » Sat Jul 21, 2012 10:03 pm
fabricated & welded in the o/s rear jacking point :D
1978 Pageant Blue 1.3 Special
1982 Morris 575 pickup
1982 Mini 1000 HLE
1988 CBR 400rr baby blade
1955 James captain 197cc
1977 Antic Weslake
"ON A SPECIAL MISSION"
Post by JubileeNut » Sun Jul 22, 2012 8:32 am
Popped both front and rear wind screens back in :thumbup:
Front was fine, rear was an absolute Bas**** :o
After a call to Frank we worked out it was a MK2 rear rubber with drain holes which fits the stainless trim.
As the MK1 has no drian holes in the body the seal had to be sealed completely.
Problem was it was so so tight compare to the 'dick in a bucket' old seal which was perished.
The good news is it is in, the bad news is that the rubber being slightly longer and tight the stainless joiner now does not reach :o . (means the inside screen part of the rubber is wider than the old one) I have a plan to sort this out and we decided to carry on the fitting after the 3rd attempt at putting it in, even though I had lost 2 inches of the stainless trim by it popping out. this was rectified after wards with a home made tool to flip the seal back round the trim.
Interestingly the best way to stop the rubber and screen moving up and then not going back down was to have a loop at the top and the bottom to pull the rubber round the body. This fixed it in place and was the only way to get it in :idea:
IF it leaks now it is not coming back out :crazy:
Just refitting rear seat today and driving back home :thumbup:
Post by JoshWard » Sun Jul 22, 2012 10:12 am
JubileeNut wrote: As the MK1 has no drian holes in the body
Late ones did :wink:
Post by MarinaCoupe » Sun Jul 22, 2012 4:14 pm
Didn't do anything to either car as went out to visit relatives. But made a detour to pick up 9 reconditioned steering racks that I agreed to buy from a guy back in May. One Mk2/Mk3/Ital and Seven Mk1s and an Italian manufactured Mk1.
I can't guarantee them as I didn't do the reconditioning work myself. There's no packaging and they won't fit in an envelope, so I'll bring any orders to P'boro.
£25.00 each - PM me if interested.
I would have put this in the Classifieds but I can't see them from my iPhone.
http://www.marinacoupe.co.uk
Barmy
Post by Barmy » Sun Jul 22, 2012 11:17 pm
cut out loads of rust & started replacing with new steel :D
1982 Mini 1000 HLE
1977 Antic Weslake
Barmy
Post by Barmy » Sun Jul 22, 2012 11:23 pm
PM sent ::):
1982 Mini 1000 HLE
1977 Antic Weslake
Post by ado28 » Tue Jul 24, 2012 2:30 am
I never got a chance to do anything as it was peeing down all day here so I took Reynard shopping for some camping essentials for Peterborough :)
