Washed off the Scarborough seagull poo!
I punched mine up the froat...
Went like a very went thing.
- northeastmarina
Well last night i fitted the new water pump,
Then found the radiator has a hole in it
But lucky me i had a spare radiator,it made sence to fit new hoses at the same time.
I also gave it a oil + filter change,new spark plugs,fanbelt,coolant flush.
BRITISH IS BEST
Was gonna make a start on touching the paint in on Reynard as it was lovely and sunny while I was at work today ,then when I finished it started to rain so instead I took the wife's car to visit the nice MOT man instead and it passed
Its still raining so I'm gonna hunt the shed for suspension bits so I can build up 2 new uprights for Reynard
- 1972TCCOUPE
With the first coat of paint I let it dry for 48hrs and it still peeled off unless I drove into the garage completly straight.I had to sand off the scrubs and will let this dry for longer
- Viscount Orange Biscuit
i used the blue coupe to drive to work in, so much better than my modern car, got to work with a smile on my face
My Marinas
MMOC 2805
MMOC 2805
My aerial extension cable arrived today so I fitted that! When driving home I heard slight exhaust noise and noticed that I had a hole in the backbox and that my hanger had rotted away. I fitted a new hanger to it and filled the hole with some gum gum. I hope it holds until I can source a new exhaust for it. Does anyone know if they still do mild steel systems for the Marina? I know about the stainless system but will need to save up the pennies for that fella and I'm about to spend £260 on some rubber for him as I will feel safer driving to Peterborough with new tyres on it
I think Larry has a few in his garage
I will give Larry a try tomorrow Paul
I have found a rear section so just need the front section now
4 new tyres ordered so they should be delivered and ready for fitting on Wednesday at a garage along the road from me. Now to go out and try and do something with my rotten exhaust
Bugger, snapped a shocker driving back from Manchester over the A57 Snake Pass!
Not long since i fitted these either.
Replaced broken shocker.
Test drive to the supermarket.
ooft, that looks sore Tony. I'm going to be rebuilding Reynards front suspension so I think I will just do the back too now lol
I wouldn't worry too much Sean, i think it was more a case of faulty manufacture, as the shocker was almost new:
The welded joint is very small here:
If it wasn't NOS i'd take it back.
- vermillion
Collected mine from the uphosterer today and am over the moon just need the new carbs now and a pair of bump stops then it's off to the mot station
Pics can be seen in the Mumford thread.
Gary.
Gary.
