over the wall..again!!
- martinmarina
- The General
- martinmarina
- Clan Chieftain
- The General
- The General
i was just taking it easy, after all you need to keep fit at your agelarryital wrote:8) you will notice who is doing all the work,while he sits on his bahooky (arse) while i get dirty!! coffee was good though. looks as if he is going to swap bumpers as the vermillion ? one has chrome ones. thanks for the coffee and the use of your lavvy stu...see you next year.
- Clan Chieftain
- The General
- Clan Chieftain
- The General
- Clan Chieftain
- The General
- The General
- stuthegasman
thanks for bringing her down boys much appreciated nice to see you all this side of the wall and the weather was nice and sunny what more can I say the dog went banana's all afternoon so well wound up there...... thanks Ray
i'm going to do it up and sell her on then buy one of them there A frames they look b****y handy i'll keep you posted of the progress etc
thanks again boys
you and your dad are always welcome down this way that goes for any of the other lads from t'other side 'o' wall as well if you ever get fed up of the rain and fancy some sunshine you know where to come we could have a top night out
stu
thanks again boys
stu
- stuthegasman
got stuck into it already with the grinder sadly the o/s headlamp panel dissintegrated and all the fibre glass and stuff holing it together fell out so I have plated it and welded it up, I took the aerial out and ground it back and that is all solid I also ground out the rot at the front of the o/s wing and made up a patch and let that in the only other bit of welding needed is in the boot under the spare wheel looks a bit tricky making up a patch for that but them bloody arch trims cause more harm than good 3 out of 4 arches have suffered in some ways but at least it is rock solid underneath floors, sills and inner wings etc look very good i'm going to take the tc alloys off and put it back on standard wheels and trims might sell the wheels as they are fitted with 4 nearly new michelin energy 155 80 13s tyres so must be woth a few quid to someone probably stick em on the bay,
here are a couple of pictures work done so far
stu
stu
