A-Plus Engine
Richard_Wale
A-Plus Engine
Post by Richard_Wale » Wed Mar 05, 2014 11:13 pm
I am hoping someone has the answer to this question?
Was the 1275 A-Plus engine fitted in the later Marinas or Itals? If so what by-pass circuit was used? Did it retain the pump to head by-pass hose, or used the sandwich block like the Metros and Minis?
A-Plus Engine
Post by MarinaCoupe » Thu Mar 06, 2014 6:22 am
The A Plus engine was used in 1.3 Itals from 1980. The pump retained the bypass hose to the head. The pump used a viscous fan rather than a fixed fan, so the end if the pump shaft has a threaded section rather than a flange.
Richard_Wale
Re: A-Plus Engine
Post by Richard_Wale » Thu Mar 06, 2014 8:07 am
Thanks very much for the quick reply.
