BATTERY
marina1300coupe
BATTERY
Post by marina1300coupe » Sun Aug 17, 2014 1:04 pm
Once again the time for a new battery has arrived. Been doing the usual checking wth local supplies. I have always used a major brand name and want to do so again. Gave the RAC a call because their online Reg checker shows nothing for my Marina. They prescribed the EXIDE EXCELL EB451, which interests me because I got almost NINE years out of my current EXIDE, however this product code is unfamiliar, usually TYPE038. Anyone know anything about this battery?
Thanks
Ian
(yes, it is cheaper to buy through Amazon)
BATTERY
Post by MarinaCoupe » Sun Aug 17, 2014 2:30 pm
Go for a type 015 more cranking power than the 038, it's listed as the optional high power battery for the Marina/Ital according to my period Lucas catalogue.
Rated at 40-42 AmpHr
EBay search http://m.ebay.co.uk/sch/i.html?_nkw=015 ... rom=refine
marina1300coupe
Re: BATTERY
Post by marina1300coupe » Mon Aug 18, 2014 9:20 am
MarinaCoupe wrote:Go for a type 015 more cranking power than the 038, it's listed as the optional high power battery for the Marina/Ital according to my period Lucas catalogue.
Thanks Chris for the response. You have bypassed my original question 'anyone know anything about this battery?'. It is possible that the EXIDE EXCELL EB451 is a type 015 in disguise.
The next battery will be the fifth I have purchased for this vehicle. Previous four have been two type 015 and two type 038 HEAVY DUTY. I have not observed any difference in performance between the two types and the type 038s lasted longer.
I may avoid this battery and purchase an item which is clearly marked type 015 or 038.
Ian
Re: BATTERY
Post by balmy » Mon Aug 18, 2014 10:16 am
My advice would be to buy a black Varta battery. Got Varta on both bikes and the TC and are excellent. Can't think what the code is on the TC one as it's a slightly bigger size than a 015 but gives better cranking power.
BATTERY
Post by MarinaCoupe » Mon Aug 18, 2014 10:25 am
Hi no the EB451 is a different shape, taller and not as long. The battery terminals are the same though. If you are looking at EBay search that I listed it will have my thing with the word battery and the digits 015 in the title.
Taking David's point about Varta batteries, I have always found them the best too.
Here is a link to the Varta website and their recommendations for the Marina.
http://www.varta-automotive.com/en-gb/s ... type=13848
Re: BATTERY
Post by balmy » Mon Aug 18, 2014 11:08 am
B24 rings a bell and it's the black type so think that's the one I have.
Re: BATTERY
Post by PHUQ » Mon Aug 18, 2014 12:18 pm
I've a Halfords own brand (bought with a trade card) 038 on Mud & it's been brilliant- i.e. I left the car outside for about 5 months over winter without even disconnecting the battery & it started the car on a cold Februrary day, after a quick spin round the block and half hour ticking over it then got left for another couple of months and again started the car. It's a few years old as well now. Sufficiently impressed to buy another for the Mk2.
Re: BATTERY
Post by MARINAMADBAZ » Mon Aug 18, 2014 1:02 pm
I too have halfords batteries on my cars
recommended
baz
SLOW ITAL
Re: BATTERY
Post by SLOW ITAL » Mon Aug 18, 2014 2:14 pm
Ian, look out for the difference in height with this EB341 .
Chris said its 25mm taller, I just bought a nice Yuasa ybx5057 48ah battery , saw it at Halfords, but got a much better deal on line.
Exactly the same , its 25mm taller, the battery pos cable would barely stretch to fit the lug on, & gives no slack for engine movement, Ive made a new longer pos lead up to be safe.
I like the battery, but it was something I missed when checking it out.
Gil.
SLOW ITAL
Re: BATTERY
Post by SLOW ITAL » Mon Aug 18, 2014 2:20 pm
SLOW ITAL wrote:Ian, look out for the difference in height with this EB341 .
Gil.
Sorry eb451
Re: BATTERY
Post by MarinaCoupe » Mon Aug 18, 2014 5:26 pm
I used a pair of quick release battery clamps on my Coupe. Each time I put her in the garage I remove the clamps to isolate the battery. The pictures the negative earth without its blue cover.
marina1300coupe
Re: BATTERY
Post by marina1300coupe » Mon Aug 25, 2014 10:36 am
Thanks everyone for your input. Have not yet had time to get it sorted.
However, just been looking at the link to the VARTA site and note that the Marina recommended batteries are all higher than the Type 015/038 and the Black VARTA B24 has the same dimensions (shorter) as the EXIDE EB451. In view of the comments regarding additional height I raised my battery 25mm using a wooden block to check on cables, whilst they fit it is not ideal.
Couple of quotes I received were for a PLATINUM battery one being KWIK FIT £82.00!!!. Looking at the PLATINUM website I see that this company sells/markets/distributes several other brands including TUNGSTONE. Bought one of these back in 1987, was HAWKER SIDDELEY TUNGSTONE then, lasted 8.3 years. All the brands on this website are the correct size, although a diagram indicates positive on right but sellers state positive on left.
Ian
Re: BATTERY
Post by balmy » Mon Aug 25, 2014 11:54 am
My Varta fitted without extending the cables.
SLOW ITAL
Re: BATTERY
Post by SLOW ITAL » Tue Aug 26, 2014 12:01 pm
balmy wrote:My Varta fitted without extending the cables.
David , I only mentioned the Battery height causing me a problem because it was something I missed.
when looking for a replacement battery.
In my case I've got a pre-engaged starter on the auto, with the battery cable going directly to the solenoid on the starter.
That extra 25mm height meant the battery was under tension & once the battery clamp was fitted, any engine movement, would've tried to pull the pos post off. Thats even removing the cable guide.
For cars with an inertia starters, with the solenoid on the inner wing it might be perfectly ok.
I'd got spare battery cable & lugs so made a new one with some "wiggle room" so its now ok.
Just tried to save someone else making the same mistake.
GIL.
SLOW ITAL
Re: BATTERY
Post by SLOW ITAL » Tue Aug 26, 2014 12:36 pm
Pickys of new cable.
