- 1972TCCOUPE
Bought myself a new knob!
Cool, I've been thinking of making these
Last edited by Morris McKinnon on Mon Feb 29, 2016 10:23 pm, edited 1 time in total.
Had a little time today. Fitted my mini cooper pancake filters. Routed the washer tubing and jets. Fitted polybushes to my spare eyebolts in readiness for my upcoming mot. At the same time i removed the sherpa shock absorber bushes as they differ in fixing diameter to the woodhead tele kit . Im guessing that some landrover poly ones may fit . Plentiful and cheap. Bit on the tight side to fit but soaking both the bush and eyebolts in very hot water helps.
Had a little time today. Fitted my mini cooper pancake filters. Routed the washer tubing and jets. Fitted polybushes to my spare eyebolts in readiness for my upcoming mot. At the same time i removed the new sherpa shock absorber bushes as they differ in fixing diameter to the woodhead tele kit . Im guessing that some landrover poly ones may fit . Plentiful and cheap. Bit on the tight side to fit but soaking both the bush and eyebolts in very hot water helps.Already have top hat (to do) and tierods done in poly.
Can you claim from the council for repairs, or sue the council for supplying a road that is not "fit for purpose"?
http://www.rac.co.uk/forum/showthread.p ... elp-please
Our local Tesco had them and after a barrage of complaints they replaced them with larger ones (the type you see everyday on the road)
Big day Saturday.
My red estate developed a problem with the auto slipping in top gear. I know what that is - but it requires a total strip of the auto and I do not have the time right now.
As I am stripping another 2 Litre unit, I decided to swap engine/transmission as a unit.
Did that two weeks ago, but there were a few other issues.
Such as;
Rear axle - both half shafts moving in the wheel bearings
Prop shaft - centre bearing collapsed plus one universal shagged
Both front brake lines cracked
Speedo cable queer
Exhaust leaking through a hole in the header
Blah blah woof woof...
Have now swapped entire rear end from donor car, including speedo cable, fitted brand new prop centre bearing, fitted another entire exhaust, still brake lines to do and will swap out entire brake master cylinder/booster.
Tonight looking like this..
In other news - was working today on a series I XJ6 which was masquerading as an XJ5. Got it sorted and here it is parked next to my 1905cc B series Mk3.
The Marina sounds best...
Such as;
Speedo cable queer
That colour really suits the Jag
. Is it the same burgundy as one of your Marina's?
No - slightly more of a bronze quality to it.
Have not sighted the maroon Marina since it sold...
Had to be towed home as the spare cap I had was for the earlier type distributor
Unbelievable
That's just unlucky, how old was it?
I think I changed the cap along with the points not too long ago to be honest.MarinaCoupe wrote:That's just unlucky, how old was it?
I didn't do nothing to my Marina today... I'm still crying from what my girlfriend did to it last week
While coming back from Christmas shopping a bus had stopped outside our driveway and my girlfriend miss judged the gap and gave the bus a good old kiss on the way in! It's only a car and no one was hurt so not all bad.... I have another
Oh well, I don't have the time or money to even think about fixing this so REP may be up for sale in the new year so I can concentrate on finishing PTH.
Merry Christmas to everyone here and thank you all so much for the help and advice you've all given me
I'll speak to you all in the new year when hopefully PTH will be looking all shiny and new with a fresh MOT.... and far away from any bus stops!
Oh no
Glad to hear everybody is OK
Typical that it didn't happen before you had nice shiny new paint!
If it's money you need you could always sell PTH
Hope you and your family have a good Christmas
Merry Christmas to you too Josh.JoshWard wrote:Oh noGlad to hear everybody is OK
If it's money you need you could always sell PTH![]()
Yep, Murphy's law it would happen After the paint went on and at the most expensive time of the year
Sell PTH? ah, crafty sod
