stuthegasman
Post
by stuthegasman » Tue Jun 19, 2007 8:30 pm
does anyone have a n/s/f bumper end cap for a mk3 I have now painted the car and managed to sort the bent bumpers there just one end cap missing then she can be put back together and used again someone must have one lying around in the back of the shed
thanks
stu
The General
Post
by The General » Tue Jun 19, 2007 9:32 pm
hi stu ive not long sold 2 new ones but i think ive got an old mk3 numper in the back shed somewhere so ill have a look and let you know.
stuthegasman
Post
by stuthegasman » Tue Jun 19, 2007 10:39 pm
thanks that would be brilliant much appreciated also you wouldn't happen to have a pair of door mirrors for the same cheeky I know or at least one for the drivers side as both are missing or do you know where I could get them if not thanks again
stu
Post
by minispeedstar » Wed Jun 20, 2007 6:21 am
stuthegasman
Post
by stuthegasman » Wed Jun 20, 2007 6:12 pm
do the mini ones not screw into the top of the doors ?? mine are fastened with 2 bolts into a triangle in the front of the door I have just had a look on ebay at metro mirrirs and they look similar do you think they will fit ??
stu
Post
by minispeedstar » Wed Jun 20, 2007 6:54 pm
No, the Metro ones have a totally different mount, the Mini "plastic" ones are the same, with the two offset bolt fixing.
The General
Post
by The General » Wed Jun 20, 2007 8:13 pm
i had a look but there ain't any on the bumper i have, sorry
stuthegasman
Post
by stuthegasman » Wed Jun 20, 2007 8:20 pm
ah well not to worry one will turn up somewhere thanks for looking
cheers stu
martinmarina
Post
by martinmarina » Fri Jun 22, 2007 5:49 pm
Hi Stu
I am removing the base model bumpers from my MK3 as I have aquired the correct chrome set with end caps and rubber all intact , so If you are interested in the base bumpers with all end caps m8 let me know .
MartinC
stuthegasman
Post
by stuthegasman » Fri Jun 22, 2007 8:53 pm
yes thanks martin all I need is the end caps really but if u want rid of the complete bumpers just let me know how much and i'll arrange to pick them up mine is an L model but has chrome ones fitted as well, I now know the mirrors I want are available from a mini so the bumpers are the only thing to finish the job off, it's only a couple of hours drive from here so collection is no problem look forward to hearing from you soon
cheers Martin,
stuart
martinmarina
Post
by martinmarina » Sat Jun 23, 2007 11:43 am
Hi Stu
how does £20.00 for the pair sound m8 , just about to clean up the chrome ones and then remove the Base bumpers .
01423 5478531 give us a buzz and we can arrange collection m8
cheers
Martin
stuthegasman
Post
by stuthegasman » Sat Jun 23, 2007 1:27 pm
sounds spot on to me i'll give u a call to arrange, you might want to give all the bolts etc a liberal dosing of wd40 a good few hours before you remove the old bumpers as I have found the mounting bolts for the plastic end caps end up snapping off as they are only plastic wouldn't want to damage them now would you.... lol
cheers,
stu
stuthegasman
Post
by stuthegasman » Tue Jun 26, 2007 8:52 pm
thanks for the bumpers Martin I just got back they're spot on, the only things I need now are a n/s/r wheelarch trim and the small strip of rubber that goes in the n/s/f bumper from the indicator round the plastic end cap if anyone has any ??
cheers stu
martinmarina
Post
by martinmarina » Wed Jun 27, 2007 5:00 pm
your welcome Stu glad to help m8
