What size tyres
aqua-marina
What size tyres
Post by aqua-marina » Sun Feb 14, 2016 1:49 pm
Well looking at the coupes tyres they're all knackered so I need 4 new ones they must be original Michelin 145x80 so skinny to say the least
What do you think for size 145 or 155 :lol:
Re: What size tyres
Post by JoshWard » Sun Feb 14, 2016 2:14 pm
165/70/13 is the largest that will fit on the rims comfortably but looks a little odd. 155s are a good compromise although I haven't had any issues with the 145/80/13s.
Re: What size tyres
Post by locost_bryan » Sun Feb 14, 2016 9:19 pm
aqua-marina wrote:Well looking at the coupes tyres they're all knackered so I need 4 new ones they must be original Michelin 145x80 so skinny to say the least
145 was standard in UK, 155 was standard in Aus and NZ. 155s on a UK car will give slightly higher gearing, so the speedo will read a couple of mph slow at motorway speeds.
Re: What size tyres
Post by MarinaCoupe » Sun Feb 14, 2016 9:30 pm
165/70 x 13 are only 0.18% difference in circumference so no appreciable difference in speedo reading. The low speed steering effort will be a little heavier.
Loads of choices at Black Circles
http://www.blackcircles.com/order/tyres ... wintertyre
Re: What size tyres
Post by Kilroy » Sun Feb 14, 2016 9:58 pm
I have always used 175/70 x 13 on standard rims.
Besides being much the same price they give the most rubber on the road.
Re: What size tyres
Post by locost_bryan » Sun Feb 14, 2016 10:26 pm
iirc 155/80, 175/70 and 205/60 are near enough the same rolling circumference, ditto for 145/80 and 165/70 (as Chris stated).
Legally in NZ, the widest tyre that will fit a 4.5" rim is 185/70, according to this chart. Which is handy, as they are what Ozzy came fitted with...
lock1506
Re: What size tyres
Post by lock1506 » Mon Feb 15, 2016 7:26 am
When I bought my 1.8 estate back it had been fitted with 145 13's and understeered terribly on the slightest bends when pushed so I put it straight back onto 175 70 13's on standard rims and normal driving was restored. I would recommend 175 70 13 for the heavier 1.8s and 155 13 for 1.3s.
hamish575
Re: What size tyres
Post by hamish575 » Mon Feb 15, 2016 9:02 am
I am running 185x60 on 5 or 5.5"rims can't remember and it handles great have not had the slightest bit of understeer yet even in heavy cornering, it has been lowered quite a bit and is running a reasonable amount of negative camber too.
Could be a different story in the wet though.
aqua-marina
Re: What size tyres
Post by aqua-marina » Mon Feb 15, 2016 12:48 pm
Think I'm going 155x13 and a good make of tyre must be a slightly better bet than the 145s keep it as original as poss
Re: What size tyres
Post by MARINAMADBAZ » Mon Feb 15, 2016 1:06 pm
yea me to 175x70x13 on standard rims fills the arches out a bit more aswell
cheers barry
Re: What size tyres
Post by Kilroy » Tue Feb 16, 2016 7:46 am
Hamish - negative camber is a side-effect of lowering Marinas due to the suspension arms being unequal length.
I would say you have between 1 and 1.5 degrees - I can vouch for the fact that 1 degree does not seem to relate to any odd tyre wear, but you do get a lot of feedback from ridges in our "lovely" roads.
There is a definite improvement to the steering though, and a quicker turn in on corners.
I run 205/60 x 13's on most of my Marinas, but am easily caught out when I drive one with standard tyres - usually losing it on the first roundabout..
