Maestro wheels
Maestro wheels
Hello, does anyone know, will a MG Maestro Lattice wheel, 6j x 15" wheel, fit a Marina, without too much fuss?
Re: Maestro wheels
No They wont fit PCD is Wrong. MGF Wheels will fit some may need spacers though, there is a thread on here about it.
Re: Maestro wheels
Sorry, don't understand. The Marina and Maestro both have a PCD of 95.25, I was just worried about the "ET". The Maestro 's ET is 28, but I don't know what the Marinas is.
Re: Maestro wheels
Yes they do, I had them on my Ital Estate, but you need bespoke spacers and the 'correct' tyres to miss the front suspension uprights. They will also find any weaknesses in your front end and steering, but do improve grip and handling immensely.nac363 wrote:Hello, does anyone know, will a MG Maestro Lattice wheel, 6j x 15" wheel, fit a Marina, without too much fuss?
Re: Maestro wheels
You will need to measure from the inner face of the wheel to the hub mount. I think it is only a 10-12mm difference, but you will need spacers and longer studs to make sure the wheels don't go walkies, also make sure your wheel bearings are in tip-top condition and set right.nac363 wrote:Sorry, don't understand. The Marina and Maestro both have a PCD of 95.25, I was just worried about the "ET". The Maestro 's ET is 28, but I don't know what the Marinas is.
Re: Maestro wheels
My apologies though they were same as van with large PCD
Re: Maestro wheels
Many thanks, for all the detailed answers. Alistair
