Drive train oil seals
Chicken Hawk
Can anybody recommend where to get axle and gearbox oil seals? I have replaced the seals in the gearbox plus axle in the spring and the axle/diff keeps leaking after changing it 3 times and now the gearbox has dumped most of its oil through the bell housing. Iv been using Autogears supply's, has anyone else used th products from this company? Tia
Re: Drive train oil seals
I can't comment in the quality of the seals you've used, but something to check on old machinery when changing seals is whether a groove has worn into the mating surface on the shaft where the seal runs. My experience in industrial machinery says even a bit of wear will affect the tolerances and effectiveness of the seal. Not so easy to remedy on obsolete car bits, sometimes in a factory environment we used to send stuff away to get metal sprayed to build the surface back up (though mostly that was where a bearing surface had worn). I had a new seal fitted on my Triumph 2.5 diff in 2007 but it would still weep. If you can find some identifying numbers on an old seal, or get measurements off it, it may be possible to get replacements from an industrial bearing and transmission components supplier, rather than go through the motor trade. Where I used to work we were supplied by Bearing and Transmission Supplies in Derby.
Hi Adz, Just don't push the seal fully home so the lip uses a new part of the shaft. also cross hatch the shiny surface with fine wet and dry to help the seal bed in.
Cheers,
Cheers,
Also make sure you lubricate the lip of the seal and the shaft with the same oil as its going to seal ie ep90 for rear axle so the lip doesn't get friction burns damaging it when first used
