Marina 575 Van H&H Auctions 02.09.17
Post by marina12 » Fri Aug 25, 2017 6:05 pm
Re: Marina 575 Van H&H Auctions 02.09.17
Post by Morris McKinnon » Fri Aug 25, 2017 6:16 pm
Were they still making Marina vans in 1982? I'm certain they would at least have had the mk3 style front :eh:
Post by mickthefitter » Fri Aug 25, 2017 6:36 pm
I'm not really up on the history of Marina vans, but the reg no. checks out on the DVLA database as a June 1982 registration. It failed its MoT though this year on an excessively corroded chassis leg.
Post by Pont.skins » Fri Aug 25, 2017 6:46 pm
Morris McKinnon wrote: Fri Aug 25, 2017 6:16 pm Were they still making Marina vans in 1982? I'm certain they would at least have had the mk3 style front :eh:
If it's a UK vehicle it should be a MK3 but it might be an "import" from the likes of Malta.
Post by marina12 » Fri Aug 25, 2017 7:14 pm
Someone who knows/ remembers more hopefully can fill any gaps- IIRC Marina commercials continued for a short while after the cars finished and replaced by the Ital. They were fitted with plain painted grilles ( same style as this one) and plain painted later bumpers. I see the cab is similar to earlier vans (I thought they were similar to the car but am wrong in this case)
https://www.handh.co.uk/buy/1982-morris ... -van/14317
There' a brochure some where on eBay that I' ll see if I can pick up.
Post by JoshWard » Fri Aug 25, 2017 7:41 pm
It's a UK vehicle, been owned by Harry Hayes for a long time, he rebuilt it a few years ago, was covered in a couple of editions of the Club mag.
Post by david painter » Fri Aug 25, 2017 8:00 pm
Found some old photos on fliker had mk1 1300 grill and under riders fitted with chrome hub caps then.
Post by marina12 » Fri Aug 25, 2017 8:13 pm
Thought I'd seen a picture somewhere before- looks a good one too.
Brochure from period:
http://www.ebay.co.uk/itm/Morris-vans-p ... Swr6RZmySM
Post by Morris McKinnon » Fri Aug 25, 2017 8:15 pm
Can't quite see it properly but looks to have an early valance I think :eh: I'm not picking at it, I would love this van but it seems all over the place with regards to trim and when it was registered.
Post by marina12 » Fri Aug 25, 2017 8:25 pm
Money no object would have it. Brilliant vans in the day. 10cwt useful capacity. As said before had 10cwt springs on the back of my 1300 Estate and could carry anything that fitted without it 'sitting down'.
Post by mickthefitter » Fri Aug 25, 2017 8:41 pm
Those look like very fancy seats in the interior. Surely from something else?
I've looked at the pictures on Flickr. I think the van looked a lot better with a Mk1 1300 grille.
Post by MarinaCoupe » Sat Aug 26, 2017 10:59 am
The Commercials got the Ital front end from some time in late 1982, although they already had the A plus low compression engine. My Y Reg Pickup was very late 1982. Harry retro fitted various bits from other cars including the interior.
Post by marina12 » Sat Aug 26, 2017 1:02 pm
A bit off topic: How much difference did the low compression engine make? Was the 10cwt axle lower ratio than the 1300 axle to compensate? Thanks.
Post by MarinaCoupe » Thu Aug 31, 2017 2:59 pm
There was relatively little performance difference between the high and low compression engines. They were fitted mainly to allow business to use cheap 3 Star fuel with 93 RON.
The ultra low 4.55:1 rear axle was used where heavy loads were expected, it help get vans and pickups rolling with a full load on board. A 1.3 engine pulling a 1/2 ton load needs all the help it can get.
Post by marina12 » Tue Sep 05, 2017 6:32 pm
Thanks for the reply.
Reported as going for £2951.00
https://www.handh.co.uk/auctions/result ... cle-museum
