Nothing exiting took boot lid off brown coupe & radiator frame off Ital pick up to take for soda blasting tomorrow. Then going to drop radiator off to have Sherpa core fitted. All to refit to Brown coupe, so she sure to keep her cool in France
Didn't mean you to stick 'em in the post Chris, that's very good of you- thank you.MarinaCoupe wrote: Mon Jun 04, 2018 10:15 pm No, they were in the garage and now they are in the post.
- First-Car as Marina
Decided to have a bit of a shuffle around after work as REW is now off the stands. Just need PDA round and I'll have them all home
Finally got around to fitting the tank to PTH, the proper early type that's meant to be fitted
Trying to get the breather hose on behind the tank was a nightmare! Also finished welding and filling one of the sills. I have the other sill to do and a few bubbles on the door bottoms then I'll take her to the paint shop for a touch up on the old Limeflower.
Went to a local show Thursday night. Was a made up TC there nice car running late MGB engine with Overdrive box and Dolomite Sprint wheels
Still only let me upload 1 photo per post
Dave, Ben posted in the 'Tapatalk image too large' thread in the 'Galleries' section that at the moment you have to avoid using the 'Preview' button to preview your pictures. If you upload them and place inline, and submit them immediately without preview, they all upload. I tried it last night with photos of starter motors elsewhere and it works. Ben says its a known software issue and he is waiting for an update.
Austin Ant - a failed military application? Surely it ought to be Olive Green not white? From this angle it looks a lot like a shrunken Land Rover Defender!
I will try doing next pictures like that see how I get on. Yes the Ant only ever seen one in Gaydon before
Curious rocker box shape on the Ant. If it's an A Series, it looks as though it is tilted backwards.
Fitting thermo electric fan today..
Looking good, Spal fan like mine?
How will you switch it on/off?
It's an Aeroflow. Uses a temp. switch in the hoses
Looks like an oven knob to set the point where it cuts in. .
