Post by balmy » Sun Jul 26, 2015 3:26 pm
Tried hiding it in some long grass. Image
stu1980
Post by stu1980 » Sat Aug 01, 2015 8:41 pm
loward marina today and mot yesterday
Post by Kilroy » Sat Aug 01, 2015 10:56 pm
That looks perfect. Well done.
I can only think that if more Marinas in the day looked like many on this forum - they would have demanded far more loyalty from their owners...
Post by ado28 » Sat Aug 01, 2015 11:33 pm
Looking great Stu!
stu1980
Post by stu1980 » Sun Aug 02, 2015 7:59 am
cheers fancy some revoloutions and spotlamps next 8-)
Post by balmy » Thu Aug 06, 2015 1:42 pm
Parked outside. Should I be worried? Image
Post by JubileeNut » Thu Aug 06, 2015 5:52 pm
I would be. Go out there and smash the piano up before it can do any damage.
Trace said to me, ah at least I know they have arrived on time!!!!! :o
I gave her a good talking to :shifty:
Post by locost_bryan » Sun Aug 09, 2015 5:35 am
Fitted the new battery to Ozzy. Headlights work, but not the park lights or wipers - need to get a test probe and fix the earths. Electric fuel pump kept ticking, so must be out of fuel. Engine turned over, albeit rather slowly.
Hopefully all little jobs to work on when I can get a spare hour.
Repacked some of the boxes of parts I got from Ben - had a wee flood through the garage and the bottom two boxes got a bit damp! Only clutch and suspension bits, so no harm done.
SLOW ITAL
Post by SLOW ITAL » Mon Aug 10, 2015 5:19 pm
Changed steering rack on Gabby..
Managed to pick up a new mk 2 rack & a pair of track rod ends at Peterborough, so
Been changing that... took me a few days though, (im slow).
Took it off thursday, new one on on saturday, had to get it back on its wheels to get it outside
To get doors open & torqe everything up sunday plus refit glove box etc... juest need to get it tracked now
But got rid of clunk on n/s fnt .....1 more done....
Gil... :thumbup:
SLOW ITAL
Post by SLOW ITAL » Thu Aug 13, 2015 5:53 pm
Gabby now tracked up, feels better....
Fitted pr new lucas rear fog lights & wired up, got proper switch & connector block off my old Ital harness, so looks right...
Fitted reverse warning aid while at it...
Went to Coventry Automotive ordered my 'quick rack' for the Ital from Trevor.
AOX was there looks the Dogs sweetmeats...
Still a few racks left if intrested....
Gil...
Ital harness
Post by MarinaCoupe » Thu Aug 13, 2015 6:20 pm
Bitten the bullet and started building up new 1.3 engine bottom half for the Pickup. Need to get rid of the blue smoke from the current engine on over-run - diagnosed as piston ring(s). Took my spare A plus block to my local engineers for acid dipping (to get the crud out of the waterways) and a hone or rebore as necessary.
1972TCCOUPE
Post by 1972TCCOUPE » Thu Aug 13, 2015 8:18 pm
Prepared the Mumford for the MOT tomorrow. Number plate and indicator bulb,then the fun started.Got it running with the aid of some easystart,made sure clutch was free then thought is that petrol I can smell? Opened the bonnet to find a shower of petrol,every pipe on the pressure side of the pump was split and leaking!
Had to replace all the petrol pipes under the bonnet on the pressure side,no wonder it didn't want to start.
G.
Post by MarinaCoupe » Thu Aug 13, 2015 8:25 pm
Hi Glen
What was the problem with the hoses, ethanol rotting it from the inside?
1972TCCOUPE
Post by 1972TCCOUPE » Thu Aug 13, 2015 8:49 pm
Yes,just seems odd they both failed at the same time,at least I know the pump is working well. The smell of petrol has now seeped in the house!
Post by MarinaCoupe » Thu Aug 13, 2015 8:52 pm
If the two pieces of hose were originally fitted at the same time, then they would have the same amount of exposure to the fuel.
