Carpet suppliers
Philip
Re: Carpet suppliers
Post by Philip » Thu May 04, 2017 10:37 pm
lock1506 wrote: Thu May 04, 2017 8:27 pm I normally get the latex backed carpet with heel pad and bound edges. I'm bringing the car home at the weekend from winter storage so I'll take a picture for you then.
Thank you very much! I look forward to seeing the pictures.
lock1506
Post by lock1506 » Sun May 07, 2017 5:40 pm
Pics of the carpet as promised, I must have had to cut mine for the coupe seat locking bar, the four doors don't have that so the carpet comes without that cut. Been awhile since I put it in and couldn't remember.
Post by Morris McKinnon » Sun May 07, 2017 5:53 pm
Nice. Looks a good fit too. Mine were from the guy on eBay, Carhoods I think it's called.
Philip
Post by Philip » Mon May 08, 2017 6:46 am
Thanks guys, they look good.
Are the seatbelt stalks held in with nuts and bolts? Do I need to be in two places at once to undo them? What I mean by that is do I need to be underneath and inside the car at the same time to remove, or do they bolt into threaded holes or welded nuts?
Lock, on your carpet, what's the fit like around the gear stick?
lock1506
Post by lock1506 » Mon May 08, 2017 7:15 am
Seat belt stalks are bolted into captive nuts so easy from inside the car. It was a tight fit.
Philip
Post by Philip » Mon May 08, 2017 7:48 am
Thanks for that.
On your carpet, are the edges trimmed, or finished, or just cut?
I see on Morris's carpet the edges around the gear lever look to be bound with vinyl.
I'm just trying to draw a comparison, that's all.
Post by Morris McKinnon » Mon May 08, 2017 11:44 am
Yes, mine have/had bound edges though I don't see the point in them really as their covered by the carpet retainers that holds it all down.
I cut most of the trimmed edges off on mine as it's a bugger to re-fit those carpet retainers as it is! besides, Marina's never had bound edges to the carpet.
Post by locost_bryan » Tue Nov 29, 2022 10:21 pm
Are the carpets the same in saloons, coupes and estates? Or are the rear carpets different in the coupe?
Post by MarinaCoupe » Wed Nov 30, 2022 8:37 am
Bryan - the carpets are the same as the floorpans are the same.
Post by locost_bryan » Wed Nov 30, 2022 10:10 pm
Thanks, Chris, that's what I thought, but wasn't 100% sure. :thumbup:
