Post by ClaytonSpeed » Mon Jan 18, 2016 1:20 pm
Your van may have had Walford trunnions on that have a separate threaded bolt that goes over the original leg. Do they have two grease points? You can remove the treaded bolt and put original ones back on if the threads are ok.
morris575van
Post by morris575van » Tue Jan 19, 2016 7:22 am
it has a grease nipple at the very bottom, it pops out every time i try to grease the joint, i will look into it will i need to change both sides or will one of one style on of the other be ok until it requires a refresh ?
Post by ClaytonSpeed » Tue Jan 19, 2016 10:30 am
Ideally you should change in pairs. Having two different types will have a knock on effect with your camber and ultimately steering.
Post by jiversteve » Tue Jan 19, 2016 2:45 pm
MarinaCoupe wrote:The trunnions are handed with threads running in opposite directions. Do you think you were trying to fit a left on the right or vice versa?
You should be able to manually open or close a telescopic shock absorber. There is no spring inside to push it back.
All the weight of the front of the car is supported on the torsion bars. All the shock absorbers do is control the vertical speed of the suspension, there is no real load on them unless they are moving relatively fast.
If you are blowing the grease nipple out, it's threads are probably worn. I would not expect a trunnion to have stripped threads as the nipples are a softer metal. Replacement nipples have a common British thread so readily replaced.
Provided all the old dirty grease is cleaned out of the trunion, and new grease installed, the grease nipple does very little but keep the dirt out. It's not that important as it's not a pressurised system. Even a blob of mastic will seal it temporarily.
Chris did an article in the club mag describing the history of trunnions, I don't think he included Walford's. They do appear on eBay occasionally. As said before, always change both sides, they have opposite threads.
morris575van
Post by morris575van » Tue Jan 19, 2016 3:58 pm
this nipple does not have a thread its just popped in there was thinking about tapping the trunnion and finding a nipple to suit
Post by jiversteve » Tue Jan 19, 2016 4:10 pm
morris575van wrote:this nipple does not have a thread its just popped in there was thinking about tapping the trunnion and finding a nipple to suit
In order for the nipple to stay in, it must have a thread! It seems to me that the nipple has been over tightened at some point stripping the thread off the nipple itself, possibly leaving the remains of its metal in the trunnion.
It's time to find a new 'threaded' nipple, and get a dentists pick, to remove any residue metal from the trunion itself.
No point doing anything until you have a replacement nipple with threads.
pickup-16v
Post by pickup-16v » Tue Jan 19, 2016 6:08 pm
Got my wheels from powder coat and tryed them on
May need tweaking slightly lol
Post by MarinaCoupe » Tue Jan 19, 2016 6:53 pm
Are they banded TR6 wheels? How wide are they exactly?
pickup-16v
Post by pickup-16v » Tue Jan 19, 2016 7:09 pm
Yeah banded there 15 inch ford puma wheels
Fronts the same
pickup-16v
Post by pickup-16v » Tue Jan 19, 2016 7:12 pm
235/50/15 rear and 195/50/15 front
Post by Kilroy » Wed Jan 20, 2016 12:31 am
Nice rubber..
Martec
Post by Martec » Fri Jan 22, 2016 7:48 pm
As far as the grease nipples poping out, I have also had this, as has been said some nipples are NOT threaded, so the solution is to buy new nipples with threads on, then drill and tap for the new size nipple, often they are still BSP.
In practise if the nipple pops out then it has not been greased often enough and a new trunnion is needed anyway.
My Walford trunnions have lasted over 20 years with regular greasing of both nipples .............with copperslip.
Kiwi Ute
Post by Kiwi Ute » Sat Jan 23, 2016 6:07 am
What did I do today?
Fitted new urethane bushes to my brake-reaction rods ( or whatever those rods that go forwards from the suspension arm is called).
An easy job and made for a less rattly suspension. :thumbup:
Post by MarinaCoupe » Sat Jan 23, 2016 11:21 am
They are called Tie Bars in the UK, your description is very accurate in a suspension engineering sort of way.
Post by jiversteve » Sat Jan 23, 2016 3:09 pm
Kiwi Ute wrote:What did I do today?
If you have a lot of rattles, it's the tie rod/reaction bar moving against the chassis member.
I have seen some were the rods were badly waisted, and some very oval holes in the chassis.
New poly bushes do not make up for either problem, though they do conceal it from view.
I wondered why the poly bushes were not made with a small shoulder on them to centralise them in the chassis.
