This morning I went to my local spray stores and bought some paint and lacquer for Reynard and even picked up a mini spray gun too. I also bought a pair of 6x9's speakers for the parcel shelve. Hopefully the weather will be kind to me this weekend so I can touch the paint work up and start the fit out for the ICE
ayrshirelad32
Bumble tucked up in her shed in between Bolly and Eeyore. Roland was getting work done to his front wing. I rubbed down some rust and made the mistake of pokong!. Why did i bother. However 3 days later said bottom of wing ready to be rubbed down again and painted. Took day off form working on car. Heater motor for said car arriving today yipee!. Paddington the Ital awaiting her bootlid refitted. Will paint that over the weekend hopefully. Using the everyday Omega at the mo. Saving Bumbles petrol for next weeks Dumfries show.
long live bl s tin
1978 Morris Marina 1.3 super
1979 Morris Marina 1.3l
1979 Morris Marina 1.7l
1980 Morris Ital 1.3hl
1981 Morris Ital 1.7hls
1983 Morris Ital 1,7slx
- northeastmarina
Fitting new qh waterpump after work,then strip+clean the carbs,
BRITISH IS BEST
Nothing- rain again
On the plus side my wheel cylinders are here along with new thermostat and oil filler cap- and sun is forecast for the weekend
Fitted the diff pinion seal that arrived today and back on the road.
New Brake discs and pads fitted on my everday marina
The ones on the car had a 1 inch lip of rust on them and the pads were uneven
Rain didn't stop me i worked under a large fishing umbrella
Best regards
Barry
Best regards
Barry
Today I gave Reynard some ICE
Rebuilt starter fitted and gained a new MOT.
fabricated & welded in the o/s rear jacking point
1978 Pageant Blue 1.3 Special
1982 Morris 575 pickup
1982 Mini 1000 HLE
1988 CBR 400rr baby blade
1955 James captain 197cc
1977 Antic Weslake
"ON A SPECIAL MISSION"
1982 Mini 1000 HLE
1977 Antic Weslake
Popped both front and rear wind screens back in
Front was fine, rear was an absolute Bas****
After a call to Frank we worked out it was a MK2 rear rubber with drain holes which fits the stainless trim.
As the MK1 has no drian holes in the body the seal had to be sealed completely.
Problem was it was so so tight compare to the 'dick in a bucket' old seal which was perished.
The good news is it is in, the bad news is that the rubber being slightly longer and tight the stainless joiner now does not reach
. (means the inside screen part of the rubber is wider than the old one) I have a plan to sort this out and we decided to carry on the fitting after the 3rd attempt at putting it in, even though I had lost 2 inches of the stainless trim by it popping out. this was rectified after wards with a home made tool to flip the seal back round the trim.
Interestingly the best way to stop the rubber and screen moving up and then not going back down was to have a loop at the top and the bottom to pull the rubber round the body. This fixed it in place and was the only way to get it in
IF it leaks now it is not coming back out
Just refitting rear seat today and driving back home
Late ones didJubileeNut wrote: As the MK1 has no drian holes in the body
Didn't do anything to either car as went out to visit relatives. But made a detour to pick up 9 reconditioned steering racks that I agreed to buy from a guy back in May. One Mk2/Mk3/Ital and Seven Mk1s and an Italian manufactured Mk1.
I can't guarantee them as I didn't do the reconditioning work myself. There's no packaging and they won't fit in an envelope, so I'll bring any orders to P'boro.
£25.00 each - PM me if interested.
I would have put this in the Classifieds but I can't see them from my iPhone.
http://www.marinacoupe.co.uk
cut out loads of rust & started replacing with new steel
1982 Mini 1000 HLE
1977 Antic Weslake
1982 Mini 1000 HLE
1977 Antic Weslake
PM sent
1982 Mini 1000 HLE
1977 Antic Weslake
1982 Mini 1000 HLE
1977 Antic Weslake
I never got a chance to do anything as it was peeing down all day here so I took Reynard shopping for some camping essentials for Peterborough
