'72 Coupe on Car and Classic
Post by ScreamingLordStokes » Tue Mar 20, 2018 10:42 am
'72 1.3 coupe, £1500.
https://www.carandclassic.co.uk/car/C973281
Anyone know this one?
Re: '72 Coupe on Car and Classic
Post by Morris McKinnon » Tue Mar 20, 2018 5:02 pm
Isn't that the one that had the missing rear window and bad interior?
Post by mickthefitter » Tue Mar 20, 2018 5:33 pm
Morris McKinnon wrote: Tue Mar 20, 2018 5:02 pm Isn't that the one that had the missing rear window and bad interior?
Sure is.
http://fastmarinamagazine.com/viewtopic.php?f=4&t=9946
Post by Morris McKinnon » Tue Mar 20, 2018 5:54 pm
It's looking a lot better now. I'd imagine the interior is still shot but nothing a set of seat covers can't sort out.
Looks a good car.
Post by david painter » Tue Mar 20, 2018 6:02 pm
Again I see offered for salve with no MOT did earn one on 22nd December 2016 Just Over two months prior to a Serious Fail if items were attended to properly should not be a bad car. Mileage not stated in advert claims to have sat but last pass was 11646 miles Fails and Advisories below
Reason(s) for failure
•Horn not working (1.6.2a)
•Offside Indicator tell tale inoperative (1.4.A.2a)
•Nearside Rear Direction indicator not working (1.4.A.2c)
•Offside Front Direction indicator not working (1.4.A.2c)
•Nearside Rear Stop lamp not working (1.2.1b)
•Offside Front Suspension component mounting prescribed area is excessively corroded floor to sill (2.4.A.3)
•Offside Front Suspension component mounting prescribed area is excessively corroded floor under wing (2.4.A.3)
•Nearside Rear Suspension component mounting prescribed area is excessively corroded inner sill (2.4.A.3)
•Offside Rear Suspension component mounting prescribed area is excessively corroded inner sill (2.4.A.3)
•Offside Suspension component mounting prescribed area is excessively corroded centre inner sill (2.4.A.3)
•Nearside Front Suspension component mounting prescribed area is excessively corroded jacking point (2.4.A.3)
•rear brake application uneven (3.7.B.2)
•Nearside Rear Seat belt anchorage prescribed area is excessively corroded inner sill inside car (5.2.6)
•Offside Rear Seat belt anchorage prescribed area is excessively corroded inner sill inside car (5.2.6)
Advisory notice item(s)
•nearside rear tyre side wall cracking
•offside rear tyre side wall cracking
•Offside Front Brake pipe slightly corroded under wing (3.6.B.2c)
•Offside Rear Brake pipe slightly corroded (3.6.B.2c)
