Wiper spindle problem
Brenjacques
Post by Brenjacques » Sat May 26, 2018 12:08 pm
Hi all,
I was going to change the rubber buffer/seals on my wiper spindles as they leak quite badly. Doing so I have opened a can of worms as the spindles themselves have corroded quite heavily and the thread just crumbled away from under the nut (they look to be aluminium). I think I am going to have to change the mechanism for the wipers but how easy is this to do? I imagine I will have to strip out the dash at least. Can replacement mechanisms be bought?
Re: Wiper spindle problem
Post by david painter » Sat May 26, 2018 1:19 pm
Wheel boxes quite easy to buy as were Lucas parts fitted on many British cats of the era. Remove glove box and instruments then work through the apertures.
Post by david painter » Sat May 26, 2018 1:20 pm
Meeeeeow before anyone else says its cars not cats!!
Post by MARINAMADBAZ » Sat May 26, 2018 8:03 pm
triumph stag the same
rimmers do new ones
cheers baz
IVOR DENNEY
Post by IVOR DENNEY » Sat May 26, 2018 8:43 pm
I might be wrong but I think MINI wheel boxes are the same so they will still be available
Post by Morris McKinnon » Sat May 26, 2018 9:28 pm
Mini wiper spindles are too short. Triumph Stag are the ones you need. I think TR6 and Hillman Imp are also the same.
Post by MARINAMADBAZ » Sun May 27, 2018 9:22 pm
marina/Ital part no. sames as triumph stag
37h7084
cheers baz
Post by MarinaCoupe » Mon May 28, 2018 6:23 pm
You beat me Baz 😀 37H 7084.
