Door Rubbers
Door Rubbers
Is there a fix for the door rubbers on the Marina? I bought a reproduction rubber on ebay and the fit isn't all that. The rubber looks like it seals but the trim part that clips around the frame is very thick and loose and the rubber has a small twist where it curves on the frame, not hugely impressed for £32! I recently took a chance on two new old stock door rubbers, not knowing whether they were front or back, turns out they were for the back and they're perfect. On the old worn out originals I can peel the rubber seal away from the trim so was wondering, can I buy rubber strips separately and glue them to the original trim? The rubber doesn't separate from the repros as they're all one mold so I can't use those.
Re: Door Rubbers
Have a look at Woollies or East Kent Trim Gareth, the both do rubber off the roll so might have a profile to match.
Re: Door Rubbers
Just checked East Kent and are out of stock, Woollies looks (from the pictures) the same as what I bought on eBay but it's on a roll and £3 a metre so might give it a try. Cheers
Re: Door Rubbers
