Water Pump
First-Car as Marina
Water Pump
Post by First-Car as Marina » Sat May 25, 2019 12:45 pm
So I noticed when I first put water in PDA last week it was leaking from somewhere near the water pump, but I couldn't see where. Since starting it the leak stopped but it has now come back and I can see it is coming from the hole in the bottom of the water pump, so I assume the seal has failed? I'm not sure though but one of you guys will I'm sure.
My other question is, should I just replace the seal (providing one is available and that is actually the problem), or is it not worth it and seals don't really work on a used pump so I may well fit new?
Cheers guys :thumbup:
morris_carl
Re: Water Pump
Post by morris_carl » Sat May 25, 2019 1:31 pm
Just fit new, so cheap,not worth Messing about
Sent from my CUBOT_X18_Plus using Tapatalk
Re: Water Pump
Post by MarinaCoupe » Sat May 25, 2019 7:36 pm
Go for new - plenty on line.
