Diesel bell housings are different....
Still learning about Marinas and Itals- the diesel had a different bell housing? I thought it was a 1.8. (1.7) box.
https://www.ebay.co.uk/itm/333973322596
- Attachments
- C423CB18-00A3-4013-8AD4-1DE68E3A028A.jpeg (23.88 KiB) Viewed 5713 times
- D1A7345B-5997-4207-8FAA-4E5C5A16001B.jpeg (25.91 KiB) Viewed 5715 times
Re: Diesel bell housings are different....
The Diesel bellhousing is in two halves. The cast backplate for the engine is about 2-3 inches deep covering the flywheel most of the clutch cover and then the bellhousing in your picture.
Is the actual gearbox any different? Lower ratios I think I remember?
Same gearbox ratios as standard 1.8/1.7. BL fitted them with the 1.3 diff with the 4.11:1 ratio though.
Ah ok.
This is fairly near to me.....
David - the gearbox will have the black speedo drive to match the 4.11:1 diff, to run it with a 3.63:1 diff will need the orange/red speedo drive.
The clutches are the same.
I fitted a diesel clutch in my previous Tc
