Rear axle brake pipe
Post by martinclan » Sat Oct 09, 2021 6:03 pm
I am just completing the refurb of my rear axle and am fitting the brake pipe.
Does anyone know if there is supposed to be any protection where the pipe is clipped to the axle using the little bendy strips?
Cheers Robin
Re: Rear axle brake pipe
Post by balmy » Sat Oct 09, 2021 6:25 pm
Originally mine had some rubber bits but they had mostly long since degraded. Last time I used a bit of petrol pipe, split to go over the pipe.
Post by MarinaCoupe » Sat Oct 09, 2021 9:36 pm
Same here - 1/4” (6mm) petrol hose fits perfectly.
Post by JubileeNut » Sat Oct 09, 2021 10:09 pm
I had some Ford Vac pipe which was perfect and used that in the same way.
Post by martinclan » Sun Oct 10, 2021 9:37 am
OK thanks all. Petrol pipe it is then...
Cheers Robin
