Mk1 pickup rear brake shoe size?
da55ter
Post by da55ter » Tue Nov 09, 2021 7:42 am
Online searches and my Haynes manual both say 8inch but they don't fit, they're too small. Anyone have an idea?
1974 marina pickup.
Re: Mk1 rear brake shoe size?
Post by MarinaCoupe » Tue Nov 09, 2021 8:24 am
Is this for a 10cwt van or pickup? They used different running gear to the saloons/coupes estates/7cwt vans.
The saloons/coupes estates/7cwt vans did use 8” drums.
da55ter
Post by da55ter » Tue Nov 09, 2021 9:24 am
It's a pick up
1974 marina pickup.
Re: Mk1 pickup rear brake shoe size?
Post by david painter » Tue Nov 09, 2021 1:38 pm
Can you see a Hub nut on end of half shaft (7 cwt axle) on just a flat disc ( 10 cwt axle)
da55ter
Post by da55ter » Tue Nov 09, 2021 3:06 pm
I'll have a look later on and post a pic
1974 marina pickup.
Post by balmy » Tue Nov 09, 2021 7:06 pm
Sure all pick ups are 10cwt originally
Post by locost_bryan » Tue Nov 09, 2021 7:56 pm
9" on the pickup and 10cwt van
REAR BRAKE SHOES ; MARINA PICK-UP & 10 CWT VAN '75-'80, ITAL 575 10CWT VAN '80-'84
GBS610 The shoe size is 228.6mm x 45mm which are suitable for 9" diameter drums.
https://www.angclassiccarparts.co.uk/?i=88947
REAR BRAKE SHOES ; MARINA 1300, 1700, 1800, ITAL (MANUALLY ADJUSTED BRAKES)
GBS815 These are the 1.5" wide shoes for use with the self adjusting type brakes. SIZE : 203.2mm x 38mm.
https://www.angclassiccarparts.co.uk/?i=95515
REAR BRAKE SHOES ; MARINA 1300 '71-'74, MARINA 1800 '71-'72 (SELF ADJUSTING BRAKES)
GBS746 These are the 1.5" wide shoes for use with the self adjusting type brakes. SIZE : 203.2mm x 38mm.
https://www.angclassiccarparts.co.uk/?i=53163
Post by MarinaCoupe » Tue Nov 09, 2021 8:00 pm
Yes - all pickups are 10cwt rated and use a heavy duty axle that is different from the saloon etc. the axle is the same as the early MGB Banjo axle so that’s where you need to look.
https://www.scparts.co.uk/sc_en/british ... 87024.html
da55ter
Post by da55ter » Tue Nov 09, 2021 10:00 pm
Brilliant. Thank you very much
1974 marina pickup.
