this weekend + friday as i took a day of
saw some mumford resto action . First off we started on the left hand side, a small patch to the wheel inner tub,
then it was time to remove the front wing
the inner wing wasnt bad at all just needing a small patch on top and at the very bottom lower a-panel (suprise) .
work is well underway at this stage
new front wing and lamp panel on
bonnet for the sharp-eyed of you is mkII and used only for alignment - i'm treating the old girl with a nos bonnet
sunday after some more grinding and welding i thought i would change the rear brake cylinders on my corsair for a change. ... Drove the car out of the barn, changed bort rear cyl. and the rear brake pipe. bled the brakes and was feeling quite happy. then it started to rain and as the entrance to the barn is over the field and when it rains it almost impossible to get th ecar in. so i rushed it a bit, but when entering the barn disaster struck
fu** x 10
Also the wing was full of filler the part that fell off was 13 mm thick !!
Well, as there is nobody to blame but a stupid fxxx like myself i guess next weekend will se some corsair repair rather than mumford resto....
