Telescopic front shocks
Post by Kilroy » Tue Jul 22, 2008 8:26 am
Dear fellow Marina-ists.
We had a fabulous weekend trip of about 1000k to the far reaches of this island - it was tremendous fun, and the car ran perfectly.
However - with a few gravel roads to contend with...
.. I was continually reminded of the shortcomings of the original front shock absorbers.
I have decided to try and arrange a telescopic conversion along the lines of the Ital.
Can anyone supply any photos or drawings of either the Ital fittings - or any other conversions so that I might be able to copy them please..?
I would also be happy to purchase any of those parts too.
Thanks folks.
Post by MarinaCoupe » Tue Jul 22, 2008 8:39 am
Kilroy,
Checkout my website www.marinacoupe.co.uk. I have had drawn up the plans for a top bracket and the Ital bottom bracket. The dims are shown, although they were drawn full size (1:1), don't trust the scaling as the picture creation process distorts the sizes.
stuthegasman
Post by stuthegasman » Tue Jul 22, 2008 8:49 am
Kilroy, have a look in the classifieds section on here as v6pop has put a set up for sale and there is a drawing asttatched
Post by Kilroy » Tue Jul 22, 2008 12:03 pm
Thanks guys - a great help.
Chris - the drawing for the lower bracket does not work for me. Some problem with the pdf file maybe..?
Cheers,
Post by MarinaCoupe » Tue Jul 22, 2008 12:09 pm
Hi Kilroy
Page 2 is the flat version for cutting and page 1 is the dims when welded up. All dims taken from the bracket in the picture.
What is it that you don't get mate?
Post by Kilroy » Wed Jul 23, 2008 11:56 am
No worries Chris.
For some reason my web browser would not load the pdf file yesterday - today it does.. :)
Good work - thankyou.
Will see if I can copy these - well, at least get someone else to.
Cheers.
TrialsMarina
Teles on front
Post by TrialsMarina » Thu Jul 24, 2008 3:05 pm
I have a Tele kit fitted on the front of my 76 Marina Coupe , if you need photo's I can take some the weekend.
Regards
Martin
Post by Kilroy » Thu Jul 24, 2008 8:05 pm
Martin
Any photos would be much appreciated - thanks.
Being as a picture's worth a thousand words...
crashbang
Post by crashbang » Thu Jul 24, 2008 11:18 pm
has any one had the lower bracket snap on the ital set up and has any one made up a better one ??
Post by MarinaCoupe » Fri Jul 25, 2008 8:30 am
Marinamadbaz, showed me a broken bottom bracket a couple of years ago, it was off a car he had recently bought. The cause was a combination of rust and the securing bolts being loose allowing it to flap and causing stress fractures until it failed. It had broken at the 90 degree fold, where the horizontal plate drops down to fit over the rear of the tie bar yoke bolt.
The bracket was beyond repair, and really had been caused by lack of rust protection and sloppy maintainance. As far as a fix is concerned, I'm not sure that it was fixable, a good used replacement was the order of the day.
I suppose if you were making some up, then you could fabricate it in heavier metal, but you can't brace the fold as the inside wraps round the suspension arm.
TrialsMarina
Help with photo's
Post by TrialsMarina » Sat Jul 26, 2008 6:00 pm
I have taken some photo's of the telescopic conversion on my coupe, no idea how to put them up on the site , can someone help please.
Regards
Martin
Post by Kilroy » Sun Jul 27, 2008 7:31 am
Martin
You need to post the photos on a website then link them to your post - so you need to engage one of the free services who offer this.
Failing that - email them to me and I will put them on my website and link them to the forum.
My direct email address is kilroy'at'ihug.co.nz
Cheers.
Post by Kilroy » Sun Jul 27, 2008 8:49 am
Thanks to Martin - here are some photos of another conversion kit.
These make it very clear that the top mount is over the top of the shock absorber - something that had not been clear for me until now.
I prefer the later lower mount - which will give more deflection to the telescopic shock for movement of the lower arm.
Muskydo
Tele front end
Post by Muskydo » Sun Jul 27, 2008 12:16 pm
Hi Kilroy here are some pictures of my Ital Tele dampers as factory fitted
BOTTOM BRACKET
BOTTOM BRACKET
BOTTOM BRACKET note stainless steel tie bars
BOTTOM BRACKET
Image[/img][/url]
BOTTOM BRACKET
If you want any other pictures let me know as the front is in bits now and easy to get at !
Cheers
Steve :)
Post by Kilroy » Sun Jul 27, 2008 7:16 pm
Thanks Steve
Yours appears to be the pukka Ital setup yes..?
I can see that the top arm is just a pivot - wonder if Martin's original shock still works - or if the valve has been removed..?
I see that the lower arm is different too - with an extension for the lower shock mount to bolt through.
Is this standard Ital..?
This is great stuff - I have a much better idea of how and where now - just have to acquire the bits.
Thanks again all.
