Lever arm shockabsorber oil.
cowboybob
Post by cowboybob » Sun Aug 19, 2007 11:51 am
Hi, can anyone recomend the grade/type of oil used in front lever arm shox's.
I have three set's of shox's for the Kit-Car but they all feel different, some stiff in one direction , some notchy. So I decided to strip and check some. The oil coming out was thick and lumpy, so after a good bath in degreaser and a blow out I rebuilt them using standard engine oil (just to test) and now the "cleaned" ones are working fine.
Only doubt I have is to what viscosity/grade the oil should be, or a substitute if it's not available. Was considering the Ital conversion but too much to do just yet to get this thing back on the road.
Any help or advise appreciated.
(I remeber topping these things up on marinas and moggies in my early garage days, but cant remember with what).
If it ain't broke take it apart anyway,at least you will know how it works when it does break.
Post by ClaytonSpeed » Sun Aug 19, 2007 1:27 pm
You can use EP-90 for a stiffer feel or Motorcycle damper oil as a standard substitute.
cowboybob
Post by cowboybob » Sun Aug 19, 2007 10:50 pm
Thanks for the reply's. I have two of them now filled with 15w50 synthetic oil at the moment, so this sounds somewhere in between the 30w and 75-90w of the gear oil. Might try a lighter oil in one of the other pairs and see how much difference it makes to the resistance.
Just a bit further, can anyone tell me if there are rubber seals on the two hydrolic pistions inside the unit or are they just machined to size. Has anyone else tryied to "service" theres and to what result, or has everyone just gone for the conversion??
miz484
Post by miz484 » Mon Aug 20, 2007 7:52 am
is there any kits to rebuilt the lever arm shocks for my marina!? my shocks need some bushes in the arm. anyone knows how can i rebuilt them?!
thanks
mark
cowboybob
Post by cowboybob » Mon Aug 20, 2007 11:08 pm
Lokks a pig of a job to remove the pivot shaft. When you take the top plate off, you can see it has been chiseled to between the pivots to stop it pulling out. I would imagine you would have to clean this off first before you pulled the shaft out, but then how do you re-secure the shaft to stop it "slidding" out. My advise so far is to find a good secondhand pair with no play and clean all the old oil, sludge and metal filings out, then re fill with oil of your choice. The ones ive done so far were notchy, slipping and locking, but no are smooth all the way up and down. Still not too sure what oil to put in. Might go for the 30w hydrolic oil as the cars only a light weight.
See quote below. :lol:
Mightyzorg
Post by Mightyzorg » Tue Aug 21, 2007 8:33 am
miz484 wrote:is there any kits to rebuilt the lever arm shocks for my marina!? my shocks need some bushes in the arm. anyone knows how can i rebuilt them?!
thanks
mark
There's always some of these on Ebay, usually at reasonable prices too, here's a link, have a search you'll probably find more and cheaper too.
http://cgi.ebay.co.uk/MORRIS-MARINA-SAL ... dZViewItem
miz484
Post by miz484 » Tue Aug 21, 2007 9:43 am
10x Mightyzorg & cowboybob!!
i have some lever arms spare but i wish to rebuilt them because they all have the same problem that leak the oil and the arm will need the bushes. :?
now i will try to fix one of them & i will let you know ;)
thanks
mark
Post by MarinaCoupe » Tue Aug 21, 2007 5:52 pm
Here you go - link to a company selling three different weights of Millers shocker oil.
http://jsoils.co.uk/miscellaneous.asp
