Woot.
Woot.
Post by Kilroy » Sun Dec 06, 2009 9:35 am
Just completed 2000k in 10 days in the red thing.
A combination of 2" lowering plus loads of food and toys meant we had to avoid all but the smoothest of unsealed roads - but we did.
Tekapo, Queenstown, Wanaka - all the lakes - for obvious reasons...
Only problem was a slight oil leak from the fuel pump. I chose to ignore it, as all attempts to cure this problem have failed in the past, so I will fit a new pump now we're home.
I suspect the alloy gets warped from overtightening, but I have never been able to successfully resurface one after this has happened.
Great trip.!
Cheers.
gary
Re: Woot.
Post by gary » Sun Dec 06, 2009 10:15 am
You lucky bugger Kilroy looks pretty much like you are living the dream.Nice estate car :D
Gary
1978 1300 coupe sorn (work in progress)
1975 Suzuki T500m sorn
1967 morris traveller modified in bits !
Greg Whitaker
Re: Woot.
Post by Greg Whitaker » Sun Dec 06, 2009 5:24 pm
Looks like a fantastic road trip. Great to see an estate being used for the purpose it was designed for.
Re: Woot.
Post by JubileeNut » Sun Dec 06, 2009 5:27 pm
Hi Kilroy,
That's weird as my fuel pump is leaking from the gasket nearest the engine block!
Used Wellseal when the engine was assembled and still weeping!
I am about to remove it and seal with RTV silicone but I wonder if it is warpped :idea:
I will try to re-do it and see.
Number 63
Re: Woot.
Post by Number 63 » Sun Dec 06, 2009 5:53 pm
Excellent photos & beautiful scenery. Good to see an old motor working hard and being enjoyed. 8)
I take it you had a new thermostat housing and autobox fitted sometime between the last trip and this one?
Thanks for sharing. :mrgreen:
Marinanut
Re: Woot.
Post by Marinanut » Sun Dec 06, 2009 9:36 pm
You can't half go off some people...... :wink:
Its times like this, when you've just finished a 36-hr weekend shift, mostly alone and stuck in a shotblasting machine, that seeing pics from NZ REALLY makes me want to get a visa and try my luck...... :D
Re: Woot.
Post by Kilroy » Mon Dec 07, 2009 12:36 am
Well guys - its like this...
Would you rather be at work - or on holiday.?
I was lucky enough to find a business that still pays me while I'm out on the road, so I finally smartened up.
I have spoken to a few members of this forum about it - not everyone's cup of tea - but anyone can do it, and it allows you to claim a lot of tax deductions for your home expenses.
Its international, so the UK and 14 other countries to date, and I can operate my business in any one of them.
And did I mention travel to those countries now becomes a tax claim..?
:D
That was a word from the sponsor.
As far as Marina madness goes....
a. No - I havn't replaced anything at all since the last trip.
b. I think the fuel pumps are not repairable. I have made every effort to file the mounting surfaces flat when they start leaking oil, but I have never been successful. The new pumps unfortunately require swapping the brake booster/vacuum advance attachments as they are bigger than the OEM unit - however - I have never yet had a replacement unit leak oil.!
Paul - I am talking O series here, so not sure if the B series suffers the same fate. I did replace my B series fuel pump quite early in the piece, and almost immediately, the pin holding the actuating arm came loose and the car stopped dead. Was easy to fix it by peening the edges of the alloy around the pin, but not a great start. Since then it has covered over 100,000k with no problems.. :)
c. Any car can break down, so I have no hesitation whatsoever in taking my Marinas out on the highway. I did give the red thing an oil and filter change before we left - but only because it was 4000k overdue. I'm pretty slack about oil changes...
d. If your Marina SHOULD break down, it will be very easy to fix in most cases. Parts are not so readily available, but everyone seems to know where there is one sitting in a back yard...
e. In retrospect, I realise that the fuel pump was leaking before I left. I had a mystery few drops of oil under the car that I couldn't trace - but I kept looking underneath.! Now I have found that the oil from the pump runs back and down either side of the bellhousing, arriving where I discovered it first. A little can also reach the exhaust manifold, making a rather worrying stench after taking right hand bends at speed...
f. I love going on holiday in Marinas.! Especially with the wide wheels. They get lots of looks and comments, and other road users tend to be a little more respectful. Especially when I have passed them at speed... The best bit is when they ask what evil powerplant I have fitted, and I lift the bonnet to show them a seemingly stock Marina motor.! Hahahaha.
Yes - I'm a happy boy, and this is a great country to cruise around.
If any of you should choose to visit, I will loan you a Marina to travel in.
Hows that.?
Cheers,
Re: Woot.
Post by locost_bryan » Mon Dec 07, 2009 3:19 am
Kilroy wrote:Yes - I'm a happy boy, and this is a great country to cruise around.
Hows that.?
Cheers,
As part of my little project to trace all the "live" Marinas in NZ, I pulled out the publicly available info for all the Marinas I had rego numbers for (mostly off web photos), and found that two of Kilroy's cars share my birth date (but on different years :wink: ). Spooky :shock:
