Radiator?
mikmik
Radiator?
Post by mikmik » Thu Apr 08, 2010 10:57 pm
HIya lads
Where would I get one of the above please?
Any idea how much they are new?
Thanks
Mick
crashbang
Re: Radiator?
Post by crashbang » Fri Apr 09, 2010 12:19 am
i can find out geting you old one chequed over for you £30 i think
i have fitted a skoder one from a brackers had to make a few brackets up but it seemed ok did have to do some pipe work as i got it the wrong round :roll:
Re: Radiator?
Post by MarinaCoupe » Fri Apr 09, 2010 9:28 am
There's a couple on Ebay at the moment, use this search. One will need a recore by the looks of it, but the other looks OK.
Ebay Radiator.
I had mine recored a couple of years ago at a cost of about £90, that was for an uprated core, the cores are copper so not cheap and the labour is the same whatever core you put in.
The top and bottom edge of the rads have pins on them to mount them. The top pins on 1.8/1.7s are different to 1.3s, although it is possible to find pattern rads with both sets of pins. Both rads have the same cooling capacity.
