Not sure if im posting in the right place, so feel free to put me straight!
Im just after picking someones brains (keep it clean!). After a bit of drama with a retro fit amp-meter going up in smoke on my MKII last week, I stripped the instrument panel out to investigate. Luckily, the issue was caused by the fact that the bulb for the gauge had been earthed through a fascia trim, and being a bit of a poor earth had therefore gradually burnt out the wiring whenever I had been driving with the lights on, and once it had been stripped out, everything worked fine! I was also over the moon to discover that this was the cause of my battery drain!
Anyway, I ramble... My instrument panel appears to have two main gauges (looks like this is standard) fitted into a four gauge fascia (which im guessing isn't standard). I just want to know what the two main gauges would have been from new. The one on the centre left is my speedo/tacho, and the one on the centre right is currently a blank dial (which im guessing could be used as a rev counter) with a fuel gauge on one edge and a coolant temp gauge on the other. The temp gauge doesn't work, the needle goes backward as soon as you turn the engine on, and I think the issue is that the gauge is incorrect, rather than there being a fault on the car. Can anyone confirm what this right hand gauge would have been originally? And where can I hijack a suitable replacement from?
The two retro-fit gauges either side are an oil pressure gauge to the left and the burnt out amp-meter to the right. I will probable replace the amp-meter with a clock, unless anyone has any better suggestions?
I should have thought to take a couple of pics, to make things easier, but it late and cold, so will do that tomorrow!
Take care! Emma.
