Is this a marina axle?
rusty
Post by rusty » Tue Dec 28, 2010 5:47 pm
I took this of a morris minor today, the car has a 2litre fiat twin fitted aswell, I thinks it an axle from a 1800 maria?
Re: Is this a marina axle?
Post by jiversteve » Tue Dec 28, 2010 6:28 pm
That looks Fiat to me. Have you checked the ratio??
If the twin cam and gearbox are OK someone may want to buy the whole package.
rusty
Post by rusty » Tue Dec 28, 2010 6:43 pm
rusty
Post by rusty » Tue Dec 28, 2010 6:45 pm
Post by Uncle Frank » Tue Dec 28, 2010 7:38 pm
Looks like a 10cwt van axle to me rusty, similar to that fitted to the morris J4 and the `banjo` axled MGB`s, could have come from a marina van or pick up :wink:
rusty
Post by rusty » Tue Dec 28, 2010 8:15 pm
Thanks for that uncle frank.
Post by Uncle Frank » Tue Dec 28, 2010 8:29 pm
You`re welcome mate...that is a good sturdy axle, it was used on the Abingdon - prepped ST Marinas for rallying and it will take a lot of abuse :wink:
Post by jiversteve » Tue Dec 28, 2010 8:36 pm
If its a 10cwt axle it should have a 4.56 ratio (I think)
Can you confirm the PCD of the wheel studs??
The Marlin classic trials boys would love to have it if it is.
rusty
Post by rusty » Tue Dec 28, 2010 8:41 pm
I will check the PCD and post it up tomorrow, though I do know the car has 15 inch steel wheels fitted and I was told they are ford.
rusty
Post by rusty » Wed Dec 29, 2010 12:10 pm
The PCD is 4.5, also the car has front disc set up with the same PCD
Post by MarinaCoupe » Wed Dec 29, 2010 6:25 pm
Whatever you do don't weigh it in, as a Marina 10 cwt Van axle it is worth good money, particularly if the front hubs are with the axle. As jiversteve said, they are sought after by the Marlin trials specialists.
rusty
Post by rusty » Wed Dec 29, 2010 6:47 pm
Well I am open to offers
Regards
Post by jiversteve » Wed Dec 29, 2010 10:08 pm
If it is a Marina van 10 cwt axle then the last key in the jigsaw is its ratio.
This can be simply checked using the methods described in viewtopic.php?f=13&t=3853&p=35913&hilit ... tio#p35913
It should be 4.56:1 if it is a van axle.
It's a very high ratio compared with the 3.63:1 of a 1.8 Marina or a 3.89 or 4.11 of a 1.3 Marina.
That engine must have been revving at about 4000 rpm at 60 mph unless it has a 5 speed gearbox.
Once the ratio is confirmed I dare say there will be a fair bit of interest as there are several Marlin Roadsters still active.
rusty
Post by rusty » Thu Dec 30, 2010 2:06 pm
Ive have checked the ratio using the method of one hub turning and for one hub rotation there was just over 2,1/4 turns of the prop so it looks to be the 10cwt axle.The engine is a 2 litre Fiat with a 5 speed gear box, radiator prop and the front hubs, all the part taken of a morris minor.
Im in Bristol and if anyone is interested please message me.
Post by jiversteve » Wed Jan 05, 2011 8:13 pm
Now on ebay part no 250749326501
