Tax Exemption
- MARINAMAN480
Tax Exemption
How do i go about checking to see if my campervan should be tax exempt ??? it is first registered in march 73.
but may be manufacured earlier ????
Re: Tax Exemption
I need to know if my 1300 coupe was built for 01/01/73
Re: Tax Exemption
The Spring 2012 edition of Understeer has first chassis number for 1973 manufacture, so you can work it out.
www.marinacoupe.co.uk
Sent from iPhone
Sent from iPhone
Re: Tax Exemption
iirc the cut of date was 31/1/1973 however I will stand corrected if this date is wrong lold13ker67 wrote:I need to know if my 1300 coupe was built for 01/01/73
Re: Tax Exemption
Sean
The last built date was 31/12/1972 for tax exemption. So cars first registered in early 1973 may have been built in 1972.
A club member recently checked the chassis plate on his TC, although not registered until March 1973, the chassis plate showed that it had been manufactured in 1972, so you never know until you check.
Sent from iPhone
Sent from iPhone
Re: Tax Exemption
Is this the one from Daventry? If so pm me..d13ker67 wrote:I need to know if my 1300 coupe was built for 01/01/73
www.fastmarinamagazine.com
'71 Marina Coupe 3.9 EFI V8
4 Speed ZF Auto Transmission
SD1 4 Pots with Audi discs
Heavy Duty Suspension Pack
Telescopic Dampers
