funny whine in first gear
little_blue
when i set off in first gear i get a funny little whine then in 2nd there is non. also in reverse i get a small whine.
what could it be ?
its on my morria marina mk2
what could it be ?
Most probably the reverse idle gear, it's turning on its own (idling) whilst first is selected and then fully engaged in reverse.
Before thinking about rebuilding the gearbox, make sure that the gearbox has been properly filled to the correct level with the correct grade of oil. The gear runs on plain shaft (no bearings) so lubrication is important.
www.marinacoupe.co.uk
little_blue
Re: funny whine in first gear
What grade oil and what kind should I buy so I know because the old type of oil from back in the day can't be bought I don't think
Classic Castrol oil can bought on line from there website.
EP80 or EP90
EP80 or EP90
It`s a Marina...they all whine in first and reverse!
not with a type 9 frank
You forgot about that lovely noise they all make in second 8)Uncle Frank wrote:It`s a Marina...they all whine in first and reverse!![]()
Mine does/did whine in all gears except top!JoshWard wrote:You forgot about that lovely noise they all make in second 8)Uncle Frank wrote:It`s a Marina...they all whine in first and reverse!![]()
Whatever oil you put in there make sure it isn't gl5 spec.
And GL4 I think, they have additives which attack the bronze components.
Im' looking for a rebuild on my 1300 box in the westcountry (Exeter). Mine is noisy in first and groans on overrun in second. Any body help me out ? Cheers Chris ? :?
Mines just been started on by someone in Plymouth-a company Alan Jeffries (enginetuner.co.uk) uses. Might be worth a phone call?
Thanks Balmy, have you a contact number for him by any chance........Cheers Chris.
Sorry balmy, early morning senior moment, just spotted the web address, "should have gone to specsavers " Cheers
