Passed his MOT today.
Philip
Post by Philip » Tue Aug 14, 2012 6:17 pm
Hopefully this nice weather wil hold out so I can actually use him a bit while I'm off work.
Post by MarinaCoupe » Tue Aug 14, 2012 6:48 pm
Brilliant - get out there this weekend - drive and smile and smile and smile.
www.marinacoupe.co.uk
Re: Passed his MOT today.
Post by jiversteve » Tue Aug 14, 2012 7:19 pm
Excellent. Always a nice feeling. I've got one of my cars booked for Thursday morning. I hope you have started a trend.
Post by MarinaCoupe » Tue Aug 14, 2012 7:27 pm
I need to get mine done before the end of the month.
Post by ClaytonSpeed » Tue Aug 14, 2012 7:38 pm
Same here :-)
www.fastmarinamagazine.com - Check out my V8 conversion in Readers Projects.
Post by Uncle Frank » Tue Aug 14, 2012 8:16 pm
:D Well done Phil!, now get out there and use him mate ;)
Post by JoshWard » Tue Aug 14, 2012 9:18 pm
Well done :)
Come on lets fill the roads up with 1.3 saloons :wink: My problem is now mine is roadworthy I'm not doing any jobs on it now, I just keep driving it :oops:
Post by balmy » Tue Aug 14, 2012 9:20 pm
IOW for the bank holiday Philip?
Philip
Post by Philip » Tue Aug 14, 2012 9:29 pm
Not sure. I would like to come to the IOW. I had fully intended to but life has got in the way a bit lately. What are the dates?
Philip
JoshWard wrote:Well done :)
Do you notice much difference between the 1.8 and the 1.3?
Post by balmy » Tue Aug 14, 2012 9:36 pm
Philip wrote:Not sure. I would like to come to the IOW. I had fully intended to but life has got in the way a bit lately. What are the dates?
Sat 25th for the long weekend. Bring a tent, book into Ninham camp site near shanklin - quite a few of us there! :)
Post by JoshWard » Tue Aug 14, 2012 10:22 pm
I have noticed a few differences.
0-60 is a fair bit slower in the 1.3, but Ducky currently has an overly heavy throttle (correct spring is on it's way) which may have something to do with it (it's hard putting my foot to the floor!). Once I'm up to speed the 1.3 cruises nicely.
The gearing is of course different, in bends I would previously drop into second for in the 1.8 I find myself staying in third as second sees the engine thrashing away in the 1.3, although at 50mph it seems reasonably civilised but then again I didn't have any carpets or soundproofing in the front of JWC (although my 1.3 being a DL has rubber flooring rather than carpet).
At idle I have noticed the 1.3 is a lot more civilised, it doesn't idle as smoothly as my 1.8 did but that had electronic ignition, the 1.3 seems a bit more 'refined', it doesn't surprise me to realise the A series seems more refined than the B series, after all the A series stayed in use until the 90s whereas BL saw fit to ditch the B series and develop the O series from it instead.
Handling is a lot better. My 1.8 had telescopic shocks, rear van (four leaves) leaf springs, uprated van torsion bars and poly tie bar bushes, the 1.3 has lever arm shocks and poly tie bar bushes, she may even have the early 'suicide' suspension, I'm not 100% sure when they changed over. The 1.3 seems a lot tighter around corners with less body roll. I've not driven a 1.8 with standard leaf springs and torsion bars so can't comment on how they compare as standard.
The clutch has a much lower biting point, but then again it is an entirely different clutch having the early 1 inch bore slave cylinder and 6 1/2 inch clutch.
Brakes in the 1.3 are slightly more 'interesting' being drums with no servo, but it's more of a case of getting used to them after driving around with discs upfront and a servo, they are certainly adequate at stopping the car, you just have to press your foot down harder!
Post by locost_bryan » Thu Aug 16, 2012 1:57 am
A whole lot less weight in the front of a 1.3 :o , so it shouldn't understeer as much. :-D
Post by JoshWard » Thu Aug 16, 2012 11:43 am
That's certainly how it feels to me!
Went for another run this morning with my new throttle spring and it's made acceleration a lot better, still a fair bit slower than the 1.8 (obviously!- Lost 0.5 litres, and have a smaller carb and possible a low compression engine?) but certainly workable.
I love driving it 8-)
Post by MarinaCoupe » Thu Aug 16, 2012 11:55 am
Josh
Easy to tell if engine originally low or high compression engine.
If the engine block number has an H in its High and if it has an L in it, it's low compression.
